Won't start, lights work, locks don't
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 9erNumber16, Jul 8, 2017.
  1. Jul 8, 2017 at 9:42 AM
    9erNumber16
    9erNumber16 [OP] New Member
    2005 Tacoma TRD
    I had a dead battery. While trying to jump it, the horn kept going off. Then, after switching jumper cables, we got the battery to hold a charge. It's at 75% according to my charger. The lights all work, but the doors and windows don't. Trying to use the fob just turns on the hazards, and it doesn't even try to turn over. Any ideas? 05 4D TRD.
  2. Jul 8, 2017 at 9:43 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Just replace the battery and be done with it.
    Rambo54 likes this.
  3. Jul 8, 2017 at 9:44 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Agreed. When a battery is dead, it's dead.
    Rambo54 and MattScatt28 like this.
  4. Jul 8, 2017 at 9:48 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Measure the battery voltage, before and while attempting to crank the engine--before it should be 12.6 to 12.8 V, while cranking it has to be 10.5V or better--if not the battery is shot...
    Rambo54 likes this.
  5. Jul 8, 2017 at 9:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pull the battery, have it load tested.
    Odds tell us you'll then install new battery.
  6. Jul 8, 2017 at 9:50 AM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    It'd probably be worth it to check your fuses too.
  7. Jul 8, 2017 at 9:50 AM
    TTT
    TTT Well-Known Member
    Tim
    Los Gatos, Ca
    2011 Tacoma TRD Sport
    Fox 2.0 w/reservoir, 17" Fuel Vapors, RCI skids, Pelfreybilt bumper, BAMF sliders
    Do you have a security system? Using your key, lock and unlock the door for about 5 cycles. Also check for blown fuses. If you battery holds a charge, it's fine.
  8. Jul 8, 2017 at 10:01 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    So you hooked up the jumpers cables backwards at first? If so, check fuses.
  9. Jul 8, 2017 at 10:23 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    That was my first thought, then I wondered if "after switching jumper cables" meant switching to another set?
    If initially the connections were reversed there will likely be a lot more "blown" than just fuses...
    wilcam47 likes this.
  10. Jul 8, 2017 at 10:43 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    If you reversed the jumper cables your main fuse is more than likely shot.
  11. Jul 8, 2017 at 10:56 AM
    20tacoma17
    2017 DCLB Sport AT
    I won't lie, I've done it before but noticed right away. Blew radio and wiper fuses. If it was on for any period of time, I hope it didn't reach ecu before blowing a fuse. I would change battery but check every fuse under dash and hood first. Just my thoughts.
  12. Jul 8, 2017 at 11:56 AM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Pretty much what everyone else said. Check fuses and cross your fingers you didn't fry anything else. (if you reversed the polarity)
    20(+) years ago when I was a kid my Dad had Costco replace the battery in his 1986.5 Nissan pickup. The "mechanic" was too busy BSing with us to realize he swapped the terminals. Ended up frying the ECU and most of the fuses. Expensive repair back in the day that Costco fronted the bill for.
  13. Jul 8, 2017 at 12:05 PM
    TexasWhiteIce
    Texas
    Yeah sound like you fried the Ecu since you had to get new jumper cables. Sucks
  14. Jul 8, 2017 at 12:37 PM
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    Thats what fuses are for. In the instance of an over-voltage/reverse polarity a fuse will break the circuit to protect the electrical devices connected. While your hypothesis is not impossible, it's highly unlikely.
  15. Jul 8, 2017 at 12:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    Wrong. Fuses are to protect the wiring in case of a circuit overload. The amount of time it takes a fuse to blow in a reverse polarity situation is an eternity when electronics are involved. There is a huge ongoing thread on here where AAA hooked the jump pack up backwards and fried the ECU.
    92PathSE likes this.
  16. Jul 8, 2017 at 12:48 PM
    Bebop
    Nick
    Obviously you have never hooked up the jumper cables backwards on a Honda Civic. Fuse pops right away.
    Vereor_Nox likes this.
  17. Jul 8, 2017 at 12:51 PM
    Vereor_Nox
    North California
    I will kindly disagree that the fuses are only there to protect the "wiring". I have no time or desire to debate electronics or circuitry.
    Bebop likes this.
  18. Jul 8, 2017 at 1:10 PM
    Bebop
    Nick
    As I write this I'm repairing a blower motor wiring harness on a Nissan Titan. Guess what it blew the fuse to protect the circuit.
    Vereor_Nox[QUOTED] likes this.
  19. Jul 8, 2017 at 1:18 PM
    Muddinfun
  20. Jul 8, 2017 at 1:19 PM
    Bebop
    Nick
    Lighting does strike twice. I'm still wondering if the OP had the jumper cables reversed or he had a junk pair of jumper cables.
