Won't Start Part 2- Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greatwhitewing, Aug 8, 2014.
  1. Aug 8, 2014 at 8:07 AM
    Greatwhitewing
    Greatwhitewing [OP] Well-Known Member
    Mass
    2022 SR5 V6
    05 V6. Starter won't won't even click or of course turn the motor. Just noticed electric windows don't work either, related?
    I have 12 volts to the starter at the large cable. I assume I am supposed to get 12V at the connector when the ignition switch is is turned to start, I am NOT getting any voltage change there (single wire)
    Battery is good and all fuses are good.
    Problem just showed itself one day. Had been working perfectly up till then nothing. The truck isn't registered right now and of course not started regularly but but I have a battery tender on it and fuel treatment in the gas.
    Looking for suggestions on what it might be before I call the tow truck.
    Thanks
  2. Aug 8, 2014 at 7:29 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Check your electrical connections for high resistance such as paint, oxidation or corrosion, especially your grounds. A voltage drop test would be the next step. Burned starter solenoid contacts or worn brushes are also worth checking. Sometimes tap with a hammer on the starter motor is a quick way to temporarily reseat them to start the engine.
  3. Aug 8, 2014 at 7:43 PM
    medic2230
    Murph
    Bama! Roll Tide
    Brushes may be worn down. Sometimes they can be taken out and grounded back like they should be.
    You may just need to actually charge the battery though.
  4. Aug 9, 2014 at 10:34 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Electrical connections are pretty clean. Started like brand new then a couple weeks later not even a click even with my Ram 1500 hemi jumping it.
    I am thinking maybe a rodent chewed the trigger wire or what ever the proper name for it is.
    I don't have a wiring diagram yet so I don't know where it goes to check continuity.
  5. Aug 9, 2014 at 11:19 AM
    medic2230
    Murph
    Bama! Roll Tide
    You got evidence of rodents? It could be the brushes in the starter since it's 9-10 years old. You can buy a brush kit for the starters.
  6. Aug 9, 2014 at 11:29 AM
    medic2230
    Murph
    Bama! Roll Tide
  7. Aug 9, 2014 at 11:51 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    How old is the battery and did you load-test it? Don't assume it's fine because it shows 12V.
  8. Aug 9, 2014 at 12:44 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    12 volts is not enough. You should have around 12.5 or above. Do a load test on the battery.
  9. Aug 9, 2014 at 12:50 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Quick load test- TRy to start and have your test leads on the Battery connections--NOT the battery terminals.
    report what you find.
    Takes two people-one to turn the key and the other to take readings
  10. Aug 9, 2014 at 12:52 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    if the windows do not work--no voltage!
  11. Aug 9, 2014 at 12:56 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    If you are stranded--SMACK the starter with something heavy-while turning the key to start.
  12. Aug 9, 2014 at 12:58 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Lights come on?
  13. Aug 9, 2014 at 12:58 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Waiting for a reply!
  14. Aug 9, 2014 at 1:07 PM
    DJB1
    Dave
    SLC, UT
    The starter needs amps to turn the engine over. If the battery has a bad cell it can't deliver the amps to the starter even though the remaining good cells are fully charged. That's how the battery can show 12V when you test the voltage but it can't start the truck.
  15. Aug 9, 2014 at 1:11 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Read the 1st portion of the original post.
    EVERYTHING works-just will not start?
    1st push the clutch cancel switch-same problem?
    NO click in the start position?
    Or slight click and no turn over?
  16. Aug 9, 2014 at 1:49 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    FIXED??? find the problem??
  17. Aug 9, 2014 at 5:44 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    lol works really well. :thumbsup: Used to do that all the time to the F-350s at work that are about 10yrs old and wouldn't even turn over.
  18. Aug 10, 2014 at 7:12 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Guess he found the problem-it would have been nice to let us know!
    Oh well!
    Funny the little tricks you learn over the years.
    It sure appeared that he had a "contact or Fuse" problem.
    If it was not the battery-always check the obvious FIRST.
