Won't start when cold
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mattya80, Jan 19, 2022.
  1. Jan 19, 2022 at 4:07 PM
    Mattya80
    Mattya80 [OP] New Member
    2020 TRD sport tacoma
    So I started having trouble with my 2020 Tacoma.
    When it's been below -15oc lately my car won't start at all or has a lot of trouble starting.
    I have taken it in twice to the Toyota dealer. They replaced the battery but still having the same problem. They said they can't find anything wrong with it?
    A couple of times it's started fine with remote start But when I've gotten in it and tried to restart after running for 10 mins it wouldn't restart and I've had to jump it.
    Sometimes it will start fine but the heater display temp is really dim and barely visable and the touchscreen will just freeze or take forever to start.
    Any suggestions I can take to the dealer for them to check while it's still under warranty?
  2. Jan 19, 2022 at 4:13 PM
    mhornco
    mhornco Well-Known Member
    That sounds like a bad battery even though they replaced it, or said they did. If a truck runs then you restart and have to jump it sounds like the battery is not holding a charge. Next time it does that use a multimeter and see what the voltage is. Also check to see that the connections are all tight. I have had my truck way colder than that and it cranks just fine.
    Mark77 likes this.
  3. Jan 19, 2022 at 4:15 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Welcome 2 TW!!!! :mudding:
    did you ask what the cca are on your new battery? get a diehard battery ASAP
  4. Jan 19, 2022 at 4:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    Also check that the charging system is charging the battery adequately. If it's not holding up the battery, you get a weak battery and all the problems that go with it.
    Skydvrr likes this.
  5. Jan 19, 2022 at 4:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Is it cranking? Slow? Normal?
  6. Jan 20, 2022 at 6:10 AM
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    Are these your symptoms:
    - will start fine on auto start and run normal
    - when you open the door and try to start it again, it just cranks and cranks with good voltage (in other words, it does not crank slowly)
    - when it does want to start, does it have a hard time getting to idle
    Your head unit being dim and slow is most likely because of the cold.
  7. Jan 20, 2022 at 7:01 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    For extreme cold like that you may want to upgrade to a battery with a larger capacity/CCA rating.
  8. Jan 20, 2022 at 7:11 AM
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    Not exactly extreme cold, as -15c is +5F. Hope OP got this figured out. -25F here as we speak, and my stock 2021 does not hestitate.
  9. Jan 20, 2022 at 7:23 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My stock 4 year old battery was just fine at -20C. The screen was a bit slow for a few minutes but that’s about it.
    :notsure:
    eurowner likes this.
  10. Jan 20, 2022 at 7:25 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Have you done any electrical mods to the truck that could be drawing power with it off?
  11. Jan 20, 2022 at 7:38 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Assuming the 2nd battery is good, make sure that all the battery cable connections to the chassis grounds and starter are tight. Voltage losses are greater at higher amps and lower temps.
  12. Jan 20, 2022 at 7:54 AM
    jsnow77
    jsnow77 Well-Known Member
    Jake
    New Hampshire
    2022 Limited Nightshade
    Battery -> Alternator -> Starter would be my point of attack. As the cold makes all these work a little harder. What does it sound like when it won't start? I had a failing starter few years ago, that would act normal except in the very cold, when it need a few extra cranks to get it started.
    Also helps to have a decent amount of gas in the tank to prevent freezing.
  13. Jan 20, 2022 at 8:03 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP may need a bit of basic maintenance.
    First is the battery, what is the CCA rating on it? Suggest to be well above 600 CCA, the more the better.
    Has the MAF and throttle body been cleaned? If not, it won't hurt.'
    Has the air filter been changed? If not, won't hurt.
    Spark plugs. What is their condition? Time to change?
    Oil Viscosity. Is it the correct viscosity for the temperature?
    Parasitic current draw on the battery? Be sure to turn off all accessories before starting. Give the starter all the current and voltage it wants.
