wont start when its warmed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jody Louthan, Sep 14, 2014.
  1. Sep 14, 2014 at 1:34 PM
    Jody Louthan
    Jody Louthan [OP] New Member
    1996 toyota tacoma 3.4
    My 1996 tacoma wont start when its warmed up it starts fine after its been sitting for a few hours and in the mornings but if if go somewere and turn it off and try to start it 15 or 20 mins later it wont start . I really need help with this one guys. I appreaciate any help you can give thank you
  2. Sep 14, 2014 at 1:44 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  3. Sep 14, 2014 at 1:53 PM
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    I had this problem with a '93 Acura Integra and it turned out to be the distributor cap. Mine would start once it cooled down for a while, but after driving for a while if I shut it off, it would not start up right away.
    Not sure if this is your problem and I don't know much about 1st gens, but it sounded similar. Good luck!
  4. Sep 14, 2014 at 2:02 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Maybe someone will correct me (sorry to bring the Chevy world here), but how old is your starter/solenoid? Problem I had with my hotrod Chevy LUV with a V8 was that the starter solenoid got hot and wouldn't crank it til it cooled down.
  5. Sep 14, 2014 at 2:03 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  6. Sep 14, 2014 at 3:58 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  7. Sep 14, 2014 at 4:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So it turns over but won't start?
    Maybe a Coolant Temp Sensor or Cam Position Sensor.
    Check engine wiring isn't pinched or burned around the EGR valve and you have good ground wire connections.
    Check the EGR valve moves freely, too.
    Replace dry or brittle vacuum lines.
  8. Sep 14, 2014 at 6:39 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Going through this also with mine, 95 2.7 l, I've found what is causing it, just haven't fixed it though,, on my particular problem, yours might be different, it's caused by not increasing fuel pressure for the said "hot start", mine is not doing the increase.
    My pressure reg. is good, but my ecm is not turning on my vsv for the fuel pressure increase, so, I've either got a bad ground in this circuit or that part of my ecm is not working,,, I can jump the vsv to turn it "on" and it will start.
  9. Sep 14, 2014 at 7:28 PM
    hitmans.army
    Myrtle Creek, OR
    OP, is it a crank no start, no crank, or sluggish crank no start?
  10. Sep 16, 2014 at 3:58 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    PM sent--checking status
  11. Sep 16, 2014 at 4:11 PM
    hitmans.army
    Myrtle Creek, OR
    I think he forgot about us.
  12. Sep 16, 2014 at 4:39 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I had a 67 Cougar with a 390 back in the day, was run the hell out of by all my friends and me. The same symptoms occurred when the last head job was done, and the rings went to toast. Seemed to start fine when cold, yet if it was any kinda warm it would not start for it's life.
  13. Sep 17, 2014 at 12:48 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    I remember the day!! Gas was cheap=.29 cents--Wow what a word we live in.
    IMO-fuel will go lower once we have a NEW president.
    GOP-I hope. Keystone Pipeline would help TOO.
    had a 69 camero=what a car!!!
    Cougar --NICE NICE NICE!
  14. Sep 17, 2014 at 2:01 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    I was gas-jockeying when the embargo hit. Went from .29 cents to .35 cents overnight. You thought they were gonna shoot ya dead for chargin that much IF we got any gas in.
    Ah, memories.....
    1st car: 67 Plymouth Fury II
    2nd car: 68 Dodge Charger
    3rd Car: 67 Cougar (With Kawasaki 900's here and there)
    Then I got Married.........
  15. Sep 17, 2014 at 2:10 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Sounds like it could be fuel related as well....pump/filter/reg..?
  16. Sep 17, 2014 at 2:20 PM
    hitmans.army
    Myrtle Creek, OR
    I think we should have to pay the average price per gallon of the year our vehicle was built. I'd drive my car a lot more if I was only paint 18 cents per gallon.
  17. Sep 17, 2014 at 2:38 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    ..You have a 1952 Mercury...?:rolleyes:
