Won't start?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SStaco714, Jan 23, 2017.
  1. Jan 23, 2017 at 11:15 AM
    SStaco714
    SStaco714 [OP] Storm Shadow
    Daniel
    Costa Mesa
    Tacoma
    Borl a exhaust, AT tires, Rims, Lift, Retro Lights, Grill
    I have a 2009 and recently had issues starting my truck. No reaction when I turn the key except for maybe a slight click at the end? Lights turn on but no engine. Works after I crank it again? Figure it has something to do with the starter but wondered if anyone here experienced the same?
  2. Jan 23, 2017 at 11:30 AM
    splitshot37
    splitshot37 New Member
    scott
    florida
    06 Tacoma Prerunner SR5 Reg Cab Manual
    Sounds like it could be the starter, among other things. Get under the truck and take a look at the starter while you have a buddy turn the key.
  3. Jan 23, 2017 at 5:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the battery voltage.
    Check and clean the battery connections.
    How old is the battery? It could be going bad.
    If the above is OK, go to Autozone and get the battery load tested.
    It could also be the starter solenoid, but is normally the above.
  4. Feb 3, 2017 at 3:02 PM
    SStaco714
    Daniel
    Costa Mesa
    Tacoma
    Turned out to be the corrosion on the battery. Thanks guys.
    wilcam47 likes this.
  5. Feb 3, 2017 at 3:12 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Easy fix. Glad it worked out. Always check the battery first. It's the easiest.
  6. Feb 3, 2017 at 3:13 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    I had this same problem, glad you got it sorted but if it comes back it's probably the solenoid contacts as stated above. There's some good write ups on how to replace them if that's the case, it's cheap, just annoying.
  7. Feb 3, 2017 at 3:40 PM
    dawgomatic
    dawgomatic Well-Known Member
    This happened to me recently...turned the key and nothing...turned again started right up. Happened later and had to jump myself to get it to start and all the lights were flickering the whole time i drove, it was the strangest thing. Had a year old battery and it turned out to be a faulty cell in the battery...who knew.
  8. Mar 3, 2017 at 8:33 AM
    SStaco714
    Daniel
    Costa Mesa
    Tacoma
    Happened to me again. I took it back to the shop and had the starter, alternator and battery checked. All tested okay. They said I could have an issue with the ignition switch? Just have to cross my fingers every time I crank it looks like. If I get more problems I might just take it to Toyota.
