Wont turn off, blinker honks horn
Discussion in '1st Gen. Tacomas (1995-2004)' started by TLyons23, Dec 16, 2022.
  1. Dec 16, 2022 at 1:35 PM
    TLyons23
    TLyons23 [OP] Member
    NY
    97 Tacoma
    Hey all
    I have a 1997 2.4L taco
    Yesterday when I went to move the truck the horn honks while I signal.
    I thought odd, looked at a couple things on the internet and figured it might be a short or maybe ill just disconnect the horn... problem solved.
    Today, when I went to do that I opened the door and the engine oil light was on, but the keys were not in the ignition. I started it up, all lihgts went off and I drove down the block closer to my house.
    There I noticed a leak on the exhaust manifold on the left side of the engine. A bit of smoke form it burning off the hot pipes, so I shut it off and removed the keys.
    This time the oil light was still on and I noticed I can turn on the heat with out the keys being in.
    What is going on with my truck? Any ideas?
    jw_96taco likes this.
  2. Dec 16, 2022 at 1:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Check for rodent chewed wiring.
    jw_96taco and wilcam47 like this.
  3. Dec 16, 2022 at 1:39 PM
    TacoDinner
    TacoDinner Well-Known Member
    Maybe it was damaged in a flood and now all of a sudden weird shorts are appearing
  4. Dec 16, 2022 at 2:03 PM
    FrankTheTank858
    FrankTheTank858 Well-Known Member
    Frank
    Murrieta, CA
    2006 Tacoma DCSB 4WD
    Sounds like you have water entering or corrosion somewhere in your electrical system.
    check your floor under the dash for wetness or rust streaks.
  5. Dec 16, 2022 at 2:22 PM
    TLyons23
    NY
    97 Tacoma
    Interesting suggestions so far.
    Ive owned the truck for almost 15 years and it was my uncles before that, no floods.
    Think its bad to drive around in? I mean, if it starts up with no warning lights on and drives, could i be making it worse?
  6. Dec 16, 2022 at 3:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is there an aftermarket trailer wiring installed?
  7. Dec 16, 2022 at 3:10 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    This
  8. Dec 16, 2022 at 4:15 PM
    TLyons23
    NY
    97 Tacoma
    No aftermarket trailer wiring.
    Im looking for the chews, under the hood and from the floor up.
    Tomorrow the dash may some off.
    I did hear some crackling, like two small wires constantly touching each other, but saw no sparks.
    Thought it could have been outside noise, so I unplugged the battery and the noise stopped.
    If I unplug the battery, there us no way the air bag can deploy when taking off the steering wheel, right?
  9. Dec 16, 2022 at 4:27 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Taking off the steering wheel would only happen after you've eliminated other things. For sure disconnect the battery if you're going to do anything with the airbags.
  10. Dec 16, 2022 at 4:40 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Any left over parts of an alarm?
    Your horn and flashers are not switched power.
    Your issue might be poor grounding causing the interesting electrical issues.
    No need pulling everything apart to figure out the issue
  11. Dec 16, 2022 at 7:40 PM
    TLyons23
    NY
    97 Tacoma
    No old alarms.
    Grounding is something to look at.
  12. Dec 18, 2022 at 5:37 PM
    ToughTaco99
    ToughTaco99 Well-Known Member
    Jerry
    1999 White Tacoma Base
    Exhaust
    Check harness under the seat. I had a bad electrical nightmare myself and it was a wire under there. Good luck!
  13. Dec 19, 2022 at 4:49 PM
    TLyons23
    NY
    97 Tacoma
    update
    pulled the fuse under the hood for the horn
    blinkers still work but does not beep the horn when i try to turn
    i do not hear the buzzing anymore wither.
    I did notice some moisture when i took off the panel under the steering wheel.
    Maybe thats to blame?
    regardless, im driving around fine and cant make anyone mad anymore by beeping at them
    win win?
    Bivouac likes this.
