Wont turn over after command start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueBird40, Dec 20, 2022.
  1. Dec 20, 2022 at 6:23 PM
    BlueBird40
    BlueBird40 [OP] New Member
    Brett
    2017 Offroad TRD
    Hey. First time poster... Maybe this has been posted before.
    Having an issue last couple years with my truck not turning over AFTER it has already just been started with command start. I did just buy a new higher cold cranking battery last year, so I don't think its that. The electrical seems fine besides this issue.
    My command start is I think factory oem one. The truck will start fine with the remote command start fob. When I get in and press the brake the engine shuts off. Then I go to press start it again and it just clicks for 10 seconds (wont turn over). This happened 3 times last night, 3rd time it struggled mightily to start up, finally did. The year before I had this same issue.
    Now I'm not sure what goes on with command start vs a regular start, but seems like somethings not getting enough power somehow upon a hard start. I think in my safety paperwork when I bought the truck, it said that the starter had an issue and it was fixed/replaced. Is this a sign of a bad starter/ alternator or ????. What should I look into for this issue? Thnx in advance - Brett
  2. Dec 20, 2022 at 6:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Battery.
    shakerhood likes this.
  3. Dec 20, 2022 at 6:55 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You aren’t giving the battery enough time to recharge between starts and it’s probably weak on its way out.
  4. Dec 21, 2022 at 4:08 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The command start is not factory oem. They did not have that in 17. Remote start wasn't available till 2020.
    TexasWhiteIce likes this.
