Woo finally Deciding on an LT kit for my truck
Discussion in 'Long Travel Suspension' started by focotacoma, Mar 3, 2011.
  1. Mar 3, 2011 at 4:44 PM
    focotacoma
    focotacoma [OP] Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    Hey Tacomaworld I have finally decided to get LT dont on my tacoma TRD offroad.....Im going LT front and mid travel rear in order to conserve my bed space......
    Money isnt really a huge issue but, I need help deciding which brand of long travel I should go with......given that I will be using the truck also as my dd and for some highway driving, and that the lt front will be coupled with mid travel rear.....
    maybe.......
    Engage
    Camburg
    All-pro
    others.......
  2. Mar 3, 2011 at 4:48 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    What Kind of Trails you running?
    Do you want Fiberglass? If no, then AP is your best option, with keeping a Mid-Travel Rear I'd go All-Pro,
    Camburg, Total Chaos, & Engage are all more geared towards desert running but with a Mid-Travel in the rear you won't get the full potential out of it! '
    I'm sure the Long Travel Guru's will chime in!
  3. Mar 3, 2011 at 4:50 PM
    focotacoma
    Fort Collins
    Im doing mostly open stuff in the eathern utah....western colorado area
  4. Mar 3, 2011 at 4:51 PM
    theduck911
    Max
    Locked and Geared!
    I'd probably go All-Pro then, that way you'd get to keep your fenders unless you want Fiberglass!
  5. Mar 3, 2011 at 4:53 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    id go AP just cause of the highway driving you will do and also cause of the mid-travel rear, AP has a good setup for that incorporating 2" wider track per tire on the front instead of 4" and their rear setup
  6. Mar 3, 2011 at 5:49 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    if you are still planning on hitting the trails then all pro is prob the best choice for you.
    anything else will make your front track width too wide and will limit you on tight trails
    engage will especially be too wide and they still dont have their 4WD axles work out
    for your rear end options, i'd go with the stage 1 SUA kit from Defined Eng.
    http://www.definedengineering.com/products.html
  7. Mar 3, 2011 at 5:54 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Total chaos with 4wd extended cv's
  8. Mar 3, 2011 at 6:04 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    This is probably the setup that I am going to go with. I want a good all around long travel setup and this seems like the best idea. Good on all terrains.
  9. Mar 3, 2011 at 7:38 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    x2
    My friend has this exact setup
    AP lt kit with foxs
    Defined SUA kit rear with a bed cage and 16x2.5 foxs
    He can still do like 60+ mph in the desert and then go crawl with no issues
  10. Mar 3, 2011 at 9:11 PM
    focotacoma
    Fort Collins
    that looks great man i assume that would work better than doing just the full all pro set up as some suggested. Also i know engage dirastically increases track width but is tc a god compromise or is their kit pretty wide too (also built for more desert running applications)
  11. Mar 4, 2011 at 6:47 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    yeah man, the defined kit will SUA your truck but still allow you to run shocks in the stock locations, wont have to cut the bed and w/ the springs under the axle you'll get less "bucking" at high speeds when off road. great product for the price.
    the TC kit is a great product by a great company. but the kit is 3.5" wider per side and the all pro is only 2". 1.5" might not seem like much but it will be noticbly wider, totally your call. you'll still be able to do trails w/ the TC kit, it'll just be a much tighter fit
  12. Mar 4, 2011 at 6:52 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    Those TC extended axles are spendy.
    You can always run some cheep OEM axles. That is what I am doing for now. Haha
  13. Mar 4, 2011 at 6:53 AM
    04LTtacoma
    Oregon
    Really? The allpro LT kit allows you to keep stock fenders? I didn't even know that!
  14. Mar 4, 2011 at 6:55 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    That's only an option on the Gen 1s. Unfortunately the 05+ trucks can't use the Tundra axle solution.
  15. Mar 4, 2011 at 8:55 AM
    theduck911
    Max
    Locked and Geared!
    Yea, you can keep them, if you run 33's and with 35's they'll fit if you trim some, Monkey Proof & Freeze are running the kit with 35's with stock fenders!
  16. Mar 4, 2011 at 9:59 PM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    GO ENGAGE..... Make it big...:D
    Dont take short cuts on your build. Have a reputable shop build it.
    goodluck and know that if you drive it hard enough, your going break something. Its part of the game.
  17. Mar 4, 2011 at 11:41 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    I would say go Camburg or TC you cant go wrong.
  18. Mar 5, 2011 at 7:31 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    I would say that all the companies r repped by someone on here. Now you should prob call the companies and do your own homework. everyone is going to hate something or another about another company, but in reality you have to make the choice.
    Keep in mind, good fabricators can be arrogant so dont be thin skinned when talking with them. But you should have some sort of knowledge about what you r going to buy.
    If you have a bad experience, there is no need to come back on here and flame a company because who knows what happened that day.
    Good luck to u man and choose the L/T that best suits your needs.
  19. Mar 5, 2011 at 8:58 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The All Pro LT does NOT allow you to keep stock fenders if you intend to leave pavement and not bash your fenders apart. Consider your stock fenders a temporary step between LT and fiberglass if for some reason you don't do it all at the same time.
  20. Mar 5, 2011 at 9:22 PM
    04LTtacoma
    Oregon
    If I was preunner I would go with Engage. Since I am 4WD I went with the burg kit.
    Does engage make a 4WD LT kit?
