Woo Hoo just hit 888 Miles since I bought it new
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Evlkarl, Aug 1, 2019.
  1. Aug 1, 2019 at 12:45 PM
    Evlkarl
    Evlkarl [OP] Well-Known Member
    The Devil,s Bum Phoenix AZ
    2019 black SR5
    nothing big yet Tac Bar K@N Filter Side Steps
    Going on 4 weeks now and still have not hit 1K on the clock. :eek: So here is a little feedback from a guy that never owned a pimp up truck and just drove Euro Sports Cars.:D
    Likes :thumbsup:
    Love the look of the Truck specially in black !!
    Layout of the interior is very nice/good/simple and all the buttons and sticks are easy to reach the dashboard is very easy too keep clean (compare to a 2017 Mini Cooper) since it has a lot of straight lines.
    A/C works very well here in AZ and for the size of the Cabin.
    Factory Height of the Truck is perfect for my needs what I am using it for and I get still a good view to do a Bra or No Bra Check in the car next to me
    Factory Radio /Navi/Commands are very user friendly for an old fart like me to use sure if you a Google Head living in Semi Valley you want more gadgets and buttons.:D:D
    The looks of the matte black factory wheels are not bad at all.
    Driving position is good very view blind spots
    Size of the side view mirrors are big enough if you adjust them right.
    Truck handles very well for a Stock Set Up
    Dislikes :(
    The position of the cruise control is a bloody joke. I can,t count how many times I switched they wipers on going down the road at night. Can,t understand why you could not integrate this function into the steering wheel
    LDA the beeping drives me crazy it beeps when there is nothing next to me and does not beep when somebody is next to me ( have not found any info in the owners manual yet to switch it off but keep the front radar going while cruise is set or to turn the volume for the LDA off)
    Chrome wheel lock nuts from the factory when the truck has black rims why??
    The ride is a bit too much like a Caddy from 1970 with them Firestone Tires I would prefer a stiffer ride from the factory without spending the extra $$ on suspension improvements or a TRD since I don,t need a 4x4
    Steering Wheel adjustment needs to be improved it,s a joke:mad:
    Firestone 16" factory tires are a bit too girly looking for me a wider tire from the factory would be perfect.
    So overall beside the few dislikes that could be improved I have no regrets that I bought a Tacoma.
    Well that sums it pretty much up for the moment.:)
    PS If i can think of anything else down the road as far as likes/dislikes I will add to the post also feel free to put your 2 Cents in on likes and dislikes and if you made any improvements on the y "don,t likes" on your truck. Cheers.:cookiemonster:
    Coyote501 and GQ7227 like this.
  2. Aug 1, 2019 at 1:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Does mileage match the coil springs?
    Congratulations!
  3. Aug 1, 2019 at 1:26 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    On your steering wheel, push the button that looks like a car driving over a line. This will turn off that beep. Also, the LDA (lane departure) will not inform you of people next to you, it just lets you know you crossed over one of the white or yellow lines. If you have your turn signal on, the beep will not sound. The system is just designed to keep you in your own lane while driving.
    Peligro and Evlkarl[QUOTED][OP] like this.
  4. Aug 1, 2019 at 1:32 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    You’re confusing Blind Spot Monitoring (BSM) with the Lane Departure Alarm (LDA). LDA alerts you when you drift over the lines, BSM lets you know if someone is coming up behind or alongside. Both are easy to turn on/off.
    BSFord and Evlkarl[QUOTED][OP] like this.
  5. Aug 1, 2019 at 1:55 PM
    Evlkarl
    2019 black SR5
    They do bought the truck new of the lot. Also "Thank you" for the fb how to turn they LDA off. I will try it later this afternoon.
    eurowner and GQ7227 like this.
  6. Aug 1, 2019 at 2:10 PM
    MarkMN
    MarkMN Well-Known Member
    Mark
    Central Minnesota
    2019 Black Tacoma TRD OR DCLB
    That's a fairly common location for a cruise control switch.
    shakerhood and Evlkarl[OP] like this.
  7. Aug 1, 2019 at 2:16 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are you recommended to get first oil change at 1k miles?
    after I got the first 1k miles, keeping the speed under 65mph IIRC during that initial stretch, and then getting all new Toyota oil in at dealer in Alton IL
    i was set to go :D
    Evlkarl[QUOTED][OP] likes this.
  8. Aug 1, 2019 at 3:34 PM
    Evlkarl
    2019 black SR5
    Thx for the Info it is turned off.:):thumbsup:
  9. Aug 1, 2019 at 6:57 PM
    TripleEight
    TripleEight Well-Known Member
    2016 Tacoma TRD Off Road DCSB Gray
    888 is a cool number
    GQ7227 likes this.
  10. Aug 1, 2019 at 6:58 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    That's gr8!!! :cookiemonster:
    GQ7227 likes this.
  11. Aug 1, 2019 at 7:20 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Don't read TW too often and you should remain happy with your truck. :thumbsup:
    GQ7227 likes this.
  12. Aug 2, 2019 at 3:38 AM
    ICU1
    ICU1 Well-Known Member
    Toyota says this is normal.
    GQ7227 likes this.
