Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Sep 28, 2016 at 4:47 AM
    #2401
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Supposedly this stuff is UV-proof, but since they only warranty for 5 years I guess that's probably how long it's UV-proof, haha!
    But, if they're willing to warranty it for that long, even with the possibility of being in direct sun constantly, I figure that it should last a good long while behind my house, where it only really only sees direct sun for 5-6 hours a day.
    But if it turns out to be crap, I'll just put a steel roof on there instead. :notsure:
    Nickel likes this.
  2. Sep 28, 2016 at 9:27 AM
    #2402
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I'm in PA and have had that stuff on a shed roof for ~20 years. It's susceptible to cracks from branches falling on it, but it hasn't been damaged by exposure to sun. My shed is against the woods so it sees some sun but not a lot.
    Noelie84 likes this.
  3. Sep 29, 2016 at 6:45 AM
    #2403
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Congrats!
    We heat with a Pellet stove and have been averaging 3tons per winter. Last year came in under 2. We have been paying $198/ton and always buy on sale. 65 is a bit chilly for us. Our target is 70F and the Pellet stove has no problems hitting that:thumbsup:
  4. Sep 29, 2016 at 6:47 AM
    #2404
    Noelie84
    Noel
    Wales, Maine
    Good to know. Encouraging, lol.
  5. Sep 29, 2016 at 6:50 AM
    #2405
    Noelie84
    Noel
    Wales, Maine
    These fans are cheap enough and they really do a heck of a job circulating heat. They're fairly noisy, but they'll let you push the heat from the pellet stove around the house a bit more. I've got a pair that are 4 years old this year and still working fine.
    http://www.homedepot.com/p/EntreeAir-5-in-Single-Speed-Door-Frame-Fan-in-White-RR100/100080304
    robssol likes this.
  6. Sep 29, 2016 at 7:12 AM
    #2406
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    With the pellet stove, I set the thermostat around 72 (harman accentra insert). I tried the local home depot pellets (average $210/ton) and they are the cheapest around me in Massachusetts. They clogged the stove pretty quickly and had trouble igniting. Woke up to a freezing house once when the automatic start failed to get a fire going. Since then, I shell out a little more for a higher grade pellet - they burn cleaner, nice fluffy ash with minimal clinkers.
    Figured with oil I may keep it a little cooler as there wont be hot/cold spots in the house - a steady 65. Who knows, the wife and baby will dictate how warm I keep the house. Need to just bite the bullet and insulate better - could save myself a lot more.
    robssol[QUOTED] likes this.
  7. Sep 29, 2016 at 7:38 AM
    #2407
    robssol
    Rob
    S. Wisconsin
    I've been trying to talk her into a couple of these for years. Finally the leverage I need! :rolleyes:Thanks
    When we bought ours the salesman recommended against auto start, said they weren't very reliable (at that time) As it turned out we pretty much run it 24/7 when the temps get down to 20F or less:thumbsup:
  8. Sep 29, 2016 at 7:44 AM
    #2408
    Noelie84
    Noel
    Wales, Maine
    If you've got any ceiling fans, run those too. They'll help move the air around as well, and if you put them on 'reverse' they'll draw warmer air across the ceiling and blow it down to where it's more useful.
  9. Sep 29, 2016 at 7:48 AM
    #2409
    robssol
    Rob
    S. Wisconsin
    Yep, do that too. They run year round, forward in summer, reverse in winter:thumbsup:
  10. Sep 29, 2016 at 8:02 AM
    #2410
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Warmer air rises, wouldn't it make sense to run a fan foward (push air down) in winter and opposite in summer?
  11. Sep 29, 2016 at 8:09 AM
    #2411
    robssol
    Rob
    S. Wisconsin
    That would make sense, but it doesn't work as well as running in reverse and push the air across the ceiling. I know it sounds counter intuitive but it's true. Forward in the summer. Reverse in the winter:thumbsup:
    Tom Servo likes this.
  12. Sep 29, 2016 at 8:51 AM
    #2412
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    I run a wildfire in a Welenco insert in the fireplace. In case you aren't familiar with it, it has 4 tubes that pull air from in front of and below the fireplace and blow out above the fireplace, pushed by 2 small fans. It doesn't push the heat very far, but radiant takes it across the house a ways. My trick is to turn on just the fan from central air. Fireplace is on middle floor, furnace in basement, bedrooms on top floor. The furnace pulls air from about the middle of the house and blows it all around. Seems to do the job for me.
    Ignore this post...it won't help your cause
  13. Sep 29, 2016 at 5:37 PM
    #2413
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    ^This
    Ceiling fans don't change temperature in a room, but blowing air on the occupants in the summer makes them feel cooler. In the winter, you don't want air blowing on you to cool your skin. But reversing the fan will force warm air to circulate, and not just sit under the ceiling.
  14. Oct 9, 2016 at 5:21 PM
    #2414
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Question about chainsaws. I have a husky 55 and it seems that the space betweem the where there throttle trigger handle and the rest of the saw body is a little too far apart on mine. I cant fully throttle it up unless i physically squeeze the saw together. Is there some way to adjust that gap? I cant seem to find anything on the subject on the interwebs yet.
  15. Oct 9, 2016 at 6:16 PM
    #2415
    Smar969905
    Zach
    Deer Park, WA
    Sounds like you are missing a bolt or 2 right off hand. Not going to claim to be an expert on saws or even know husky. I'm running ancient McCullough and finding parts is the hardest part.
    jpneely[QUOTED] likes this.
  16. Oct 9, 2016 at 6:24 PM
    #2416
    jpneely
    Charleston, SC
    I know its supposed to flex, but it feels likes its damn near worn out and just stays with the gap wide. Are there bishings in there that can wear out? Ive never delved into this part of a saw. Im newb at it really, but man its killing me.
  17. Oct 9, 2016 at 7:22 PM
    #2417
    Smar969905
    Zach
    Deer Park, WA
    Just looked at pics online, and best I can say is tear into it and look for weak parts, stuff that is worn down, broken, etc near the handle
    jpneely likes this.
  18. Oct 10, 2016 at 4:58 AM
    #2418
    Noelie84
    Noel
    Wales, Maine
    If it's anything like my 51 (which it should be), I think there's a rubber-insulated bolt where the lower part of the handle hooks into the main saw body that holds the handle rigid against the saw body. I'd check that out first; if the bolts missing or the rubber is smoked that could give you some slop. You can check the linkage from the trigger to the carb as well, just by popping off the air filter cover, to make sure the linkage isn't bent or something. That's where I'd start.
    I'm working from memory, though. I'll take a peek at my '51 when I get home and try to give you some more specific suggestions.
  19. Oct 10, 2016 at 5:17 AM
    #2419
    jpneely
    Charleston, SC
    Thanks fellas. Ill start looking around
  20. Oct 10, 2016 at 10:37 AM
    #2420
    jpneely
    Charleston, SC
    i had a broken pin holding the trigger in place allowing the trigger to not connect with the trigger linkages in the main body.
