Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Dec 30, 2016 at 9:16 AM
    #2581
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Our area can have "no burn days" if the AQMD calls for it, but it doesn't apply if wood heat is your primary heating source.
    Once my stove gets to operating temperature and I'm burning dry wood, there are almost no visible emissions.
  2. Dec 30, 2016 at 9:55 AM
    #2582
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
  3. Dec 30, 2016 at 1:39 PM
    #2583
    OZ-T
    Peter North
    British Columbia
  4. Dec 30, 2016 at 5:18 PM
    #2584
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    As long as you have straight grain wood, and not too large around, this could be great. I'm sure it's only about $150,000 worth of equipment.
    Watt maker likes this.
  5. Jan 2, 2017 at 6:19 AM
    #2585
    ralfnjan
    ralfnjan Well-Known Member
    Fire starting. How many of us use the "upside down" start? I use it when starting from scratch (usually have coal bed from November to April for firing).
    Bottom is final sized split wood. Next up layer is smaller split, next layer kindling/cardboard/birch bark, then some newspapaer (not needed if birch bark is available). Light the top and leave it. By the time the bottom layer is burning well you add your night or day's wood. No need to tee pee or boy scout fire build. This is much faster. I do sometimes put a layer of cardboard between the bottom and second layer. The first time I did this I thought it would never work, now use nothing else.
    I burn about 5 full cords in a Pacific Energy Alderlea T6 (same firebox as the Summit). A full fuel load of Oak, Ash, Hickory or Maple will last 12 hours with coals to rake up for the next firing. Does all the heating for an 1100 square foot house, stove in the full basement.
    Ralph
  6. Jan 2, 2017 at 6:40 AM
    #2586
    Smar969905
    Zach
    Deer Park, WA
    I've never tried that, but my problem with that is mostly the wood I burn. I have mostly pine on my lot, and I've been cleaning them up since I moved here 3 years ago. I split the pine into bigger pieces intentionally so it will last longer. Otherwise, I have to get up in the middle of the night to reload the fireplace. The old furnace was dying at my house recently, and wasn't pushing any heat through the electric elements. We would load the fireplace up right before bed, load it again about midnight to 1 am, then I would have to revive it about 5am as I was getting ready for work.
  7. Jan 2, 2017 at 6:53 AM
    #2587
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  8. Jan 2, 2017 at 7:08 AM
    #2588
    rmepilot
    Rob
    Huntsville, AL
    When I had my home built, my builder thought I was crazy for having a wood burning fireplace installed. Not the norm for around here, but growing up in the PNW, I've always enjoyed the warmth and smell of a wood fire. For daily use in the winter, I have a gas fireplace too.
  9. Jan 2, 2017 at 8:07 AM
    #2589
    OZ-T
    Peter North
    British Columbia
    I'll see if I can find something on Briebart for you , hang on
    rmepilot[QUOTED] likes this.
  10. Jan 2, 2017 at 8:37 AM
    #2590
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Ok folks let's not get this thread locked.
  11. Jan 2, 2017 at 8:43 AM
    #2591
    OZ-T
    Peter North
    British Columbia
    Whateva , I do what I want
    Smar969905 likes this.
  12. Jan 2, 2017 at 8:50 AM
    #2592
    rmepilot
    Rob
    Huntsville, AL
    It is your thread...
    In other news, I'm burning a mix of hickory and cedar. Any issues with burning cedar in a fireplace? I know pine is discouraged, but this is the first time I've run cedar for heat.
  13. Jan 2, 2017 at 8:51 AM
    #2593
    OZ-T
    Peter North
    British Columbia
    Cedar can really pop a lot and throw embers , kinda depends on moisture content
    I burn it in my woodstove
    rmepilot likes this.
  14. Jan 2, 2017 at 8:56 AM
    #2594
    rmepilot
    Rob
    Huntsville, AL
    Mine has seasoned for about 8 months, but creates a very hot fire or so it seems.
    Glass doors and a chimney screen help with the sparks and embers.
  15. Jan 2, 2017 at 8:59 AM
    #2595
    OZ-T
    Peter North
    British Columbia
    You're fine
  16. Jan 2, 2017 at 5:04 PM
    #2596
    OZ-T
    Peter North
    British Columbia
    When I was s kid our medium length haired mutt used to sleep right in front of the fire and one night an ember came flying out of the fireplace and caught her hair on fire , there was a big column of stinky smoke rising up off her that obviously hadn't got to her skin yet cause she was still asleep when we got over to her to get the ember off of her lol
    Nedrolls, Nickel, Watt maker and 2 others like this.
  17. Jan 2, 2017 at 5:36 PM
    #2597
    rmepilot
    Rob
    Huntsville, AL
    :eek:
  18. Jan 11, 2017 at 6:36 PM
    #2598
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    God! ....this month I went through a bad batch of wood...it appeared to be red oak ...it was heavy , needed and to be seasoned longer. I burned it with scraps of pine from work and kept it hot. Still it left big coals I had to stir. I don't normally have this problem, but I do burn trees that are standing dead or wind blown. Just venting, but man this month was sucking for the wood I was burning. You get that scavenging around a property I guess. Anyway I have my cute kitten as a avatar:) sucks he is a dick of a cat now.
    Noelie84 likes this.
  19. Jan 12, 2017 at 4:49 AM
    #2599
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I've had the opposite problem lately, lol. I've been working through a big maple that I harvested dead standing, cut, split, & stacked and then had it at the back of the pile for 2 years seasoning some more. I realized I hadn't cycled through that wood this summer, so I put it at the front of the shed. It's so dry now that it'll light with a match, no kindling required, and it burns so hot, fast, & completely that I have to damper the stove completely back or else I'm left with just grey ash in the morning, no coals at all. Fortunately I'm almost done with it and back into regularly-seasoned wood now.
    Frkypunk and Watt maker like this.
  20. Jan 12, 2017 at 2:40 PM
    #2600
    Frkypunk
    Timmy
    Woods of P.A.
    Yeah...it's funny that there is such a thing as, too seasoned...lol...I shouldn't have that problem beacause I wait till the last month or two to fill my wood room. That why I really can't complain about that unseasoned wood because I put it in there....I will still complain though;)
