Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Sep 18, 2018 at 5:05 AM
    #3061
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I very much enjoy my pellet stove for shoulder season heating. It's nice to wake up on a cool morning and flip the thermostat for it to 'run' and then go do whatever, and to have it automatically shut off when the upstairs is up to temp. Much better than running the cookstove, where it takes a while to heat up, then you're comfortable for an hour or so and then you start opening windows.
    On the other hand, it's also really nice to have the woodstove since it's silent heat. And it'll go all night without a reload; I can fill it before I go to bed and still have plenty of coals left in the morning before I go to work. And it's the same scenario when I get home after work; house is still warm and there's still coals to relight it with. Our first winter in the house we were trying to use the wood/coal combo stove that came with the house, and it was miserable. It'd heat the house fine with coal but didn't have a big enough firebox for wood. You could either burn it hot enough to keep the house warm and refill it every 4 hours, or you could throttle it back and get 8 hours out of a burn but it wasn't keeping the house up to temp. So that stove went down the road and I installed our current soapstone beast. It's amazing what a difference the right stove will make.
    robssol likes this.
  2. Sep 18, 2018 at 7:07 AM
    #3062
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Never seen this thread before. Bought this house last year and it’s the first time I have ever had a wood stove of any type. Still lots to learn about using it correctly but it’s a Jøtul F500
    Maticuno, wdb, Noelie84 and 1 other person like this.
  3. Sep 18, 2018 at 7:45 AM
    #3063
    Noelie84
    Noel
    Wales, Maine
    Congrats! Can't beat wood heat.
    Step one is to clean the chimney. You never know how long it's been since the PO had it done, and it'll give you a baseline going forward.
    Dgibson529[QUOTED] likes this.
  4. Sep 18, 2018 at 8:12 AM
    #3064
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I was advised with my stainless steel pipes to use plastic bristles on my 'pipe cleaner'. It is said that they have a coating that the wire bristles remove.
  5. Sep 18, 2018 at 8:17 AM
    #3065
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    We used it last year but not routinely as we didn’t have much wood to begin with and we moved in December. I have someone coming out in two weeks though to clean the chimney and inspect it to make sure it’s good to go for the winter. I’m planning to burn about two cords through it this winter. Hopefully it cuts down on my oil bill because oil really hit the pockets last winter
    2Toyotas likes this.
  6. Sep 18, 2018 at 8:25 AM
    #3066
    Noelie84
    Noel
    Wales, Maine
    I've never been a fan of steel bristles anyway; I've got a clay liner in my chimney and I use a nylon brush. Don't know about any coating for the metalbestos but I'm sure it's a possibility.
    2Toyotas[QUOTED] likes this.
  7. Sep 18, 2018 at 9:05 AM
    #3067
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Wire brushes are harder than the stainless and will impart scratches potentially causing corrosion.
  8. Sep 18, 2018 at 6:14 PM
    #3068
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    We haven't started burning yet but I'm moving my firewood from my seasoning woodshed in the back 40 into the one by the house this weekend
    friendlywithbears and 2Toyotas like this.
  9. Sep 19, 2018 at 2:27 AM
    #3069
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Pellets are made of wood. Just thought you should know.:rolleyes:
    Sounds like you're planning on going through the roof with your pellet chimney. Pellet stoves that are efficient have a (relatively) cool exhaust, with a long run you'll need to power draw fresh combustion air from outside, this will also help with efficiency. I run mine directly out side to a 5' "candy cane" on the side of the house. Short run, easy cleaning, good draft. I draw my combustion air in around the exhaust pipe going out.
    Ours is rated at 42K BTU/Hr IIRC One bag a day when it gets really cold (sub-zero). We heat the whole house with it. From what I've seen pellet stoves are much cleaner than wood stoves.
  10. Sep 22, 2018 at 4:30 PM
    #3070
    OZ-T
    Peter North
    British Columbia
    Got all my firewood moved to my house woodshed from my back 40 seasoning shed today
    Real dog's breakfast this year , got some spruce , fir , cedar , maple , alder , madrone , cascara and plum in there haha
    Noelie84, robssol, wdb and 3 others like this.
  11. Sep 23, 2018 at 7:52 AM
    #3071
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Does anyone else get critters living in their woodpile? I had to deal with a snake last week. HATE dealing with snakes.
  12. Sep 23, 2018 at 8:53 AM
    #3072
    OZ-T
    Peter North
    British Columbia
    Sometimes I find a mouse house in there
  13. Sep 23, 2018 at 12:19 PM
    #3073
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Snakes, yes. We have small brown snakes and big black (rat) snakes.
    When we have black snakes we have very few mice. We like the snakes.
    I have heard that the black snake also keeps rattlers and copperheads away. We do not see them, so ....
    Ken in NC
  14. Sep 24, 2018 at 4:36 AM
    #3074
    Noelie84
    Noel
    Wales, Maine
    The split pile mostly just picks up mouse houses. The stacks of 4-footers and stove-length that hasn't been split yet occasionally picks up a garter snake, but not very often. And usually they blitz out of there as soon as I start pulling pieces out to cut up or split.
    Oz-
    Which PE stove model do you have, again? A buddy of mine is looking to install a woodstove and is looking at PE (one of the local stove shops just started carrying them) but I couldn't remember the name of yours when I was talking to him on Saturday.
    He's looking primarily at either PE or Jotul, and I told him that he really can't go wrong with either brand but that he should be ready to drop some $$ on it.
  15. Sep 24, 2018 at 7:08 AM
    #3075
    OZ-T
    Peter North
    British Columbia
    I have the Alderlea T5
    Noelie84[QUOTED] likes this.
  16. Sep 24, 2018 at 7:25 AM
    #3076
    Noelie84
    Noel
    Wales, Maine
    Ok. I think he was looking at a Vista? It's a smaller model; he's only looking to use it as a supplemental/emergency heat source for about 1000 square feet.
  17. Sep 24, 2018 at 10:09 AM
    #3077
    OZ-T
    Peter North
    British Columbia
    I have a Vista in my basement that we used to have in our old 900 sqft house , heated that area well , only drawback is the firebox is wide but not deep so you kinda have to stack the wood crossways which is a non issue with the Alderlea
  18. Sep 24, 2018 at 10:21 AM
    #3078
    Noelie84
    Noel
    Wales, Maine
    Aha, good to know. I suppose you could always cut it shorter, too, and just stuff more pieces in. But where's the fun in that? Nobody wants to deal with 10 inch firewood...
    I'll warn him about the East-West stack requirement. Thanks!
  19. Sep 24, 2018 at 12:06 PM
    #3079
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  20. Sep 24, 2018 at 12:13 PM
    #3080
    Noelie84
    Noel
    Wales, Maine
    I actually was just on PE's website; it's sneaky how they list log size. They say you can put a 16" log in the stove, but don't mention that the entire stove is only 15" deep unless you look at the dimensions diagram :laugh:
