Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Jan 23, 2019 at 7:47 AM
    #3221
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Stoves with a secondary combustion burn meet efficiency standards more economically w/o an expense of the cat. And then there is the time involved with keeping the cat clean! UGG
    wdb likes this.
  2. Jan 23, 2019 at 8:02 AM
    #3222
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yes and no; the secondary burn systems on newer stoves run cleaner because they're burning the smoke that would otherwise just go up the chimney. Burning the smoke produces more heat, so they run cleaner and produce more BTU's per cord than a traditional stove would.
    Very true. Secondary combustion stoves (with the reburn tubes) do meet the EPA standards without the expense of a catalytic combuster. My Hearthstone does a great job of heating the house without a cat, for instance. But from what I've read, all other factors (wood species, proper seasoning, air supply, etc) being equal, a catalytic stove is roughly 5%-10% more efficient than a stove using reburn tubes, when it's used properly.
    2Toyotas[QUOTED] likes this.
  3. Jan 23, 2019 at 8:34 AM
    #3223
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    7 or so years ago I had one of those (as I call them) "potbelly stoves" for my detached garage. I actually got for $25.00 at a auction in the middle of July (it was 95F). I think people were so hot that day, they got turned off by the idea of a woodstove of any knd.
    Back to the point- while the stove put a good amount of heat -it was FAR from airtight. Also it was finnicky as far as holding a fire for very long. Once my son-in-law put waaay to much really dry wood in it It was about to glow red - after I got it calmed down -I decided to get something else ASAP
    I sold the pot belly for $200.00 to a collector and found a used little Timberline for $40.00.
    The timberline has been superb and very easy to regulate.
    You are to be admired for using and working with you have there. You have a lot of patience/perseverance!
    Good luck with it -- just keep people who think they "know-it-all" away from your potbelly!
  4. Jan 23, 2019 at 10:52 AM
    #3224
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Yeah, they are not "high efficiency" by any means. If you add a "Magic Heat" to reclaim chimney losses they are pretty good though.
    As far as air tight, mine has numerous leaks. However, you can keep the damper set to where those gaps are always drawing in air and no smoke escapes. My Dad, brother-in-law, and I all burn wood stoves in our garage and have never had any issues with over heating them.
    BTW, I am in the process of installing a furnace in my garage. A friend owns HVAC business and he pulls <10 yr old units all the time as people upgrade home units for efficiency gains and to take advantage of incentives/rebates. Plan is to maintain about 45-50 degree temp and supplement with wood. Not in a hurry though. I live in an area where the local utility company has some of the highest rates in the US. Good lobbyist have helped them become owners of the state utility regulatory commissioners.
  5. Jan 23, 2019 at 2:25 PM
    #3225
    squeaky
    squeaky Well-Known Member
    Wisconsin
    2014 MGM DCSB Sport 4x4
    Ya I don't believe they make any non-catalytic stoves. I've got 4 trouble free seasons out of mine so far, but I only use very seasoned wood.
  6. Jan 23, 2019 at 8:13 PM
    #3226
    markmizzou
    Mark
    Missouri
    Great idea- I really don't know how our NG and Electric rates compare to other areas -- are there stats for this somewhere.
    You've got a friend in HVAC -- not trying to one up you , but I have a son in the trade. Like your friend -- he gets good ones on take-outs now and then. He used to sell them as used ones , but -no more - despite that he told the buyer that they were used -people were mad when they went out within a couple of years. He does not sell them that way anymore. People nowadays!!??
  7. Jan 23, 2019 at 8:18 PM
    #3227
    markmizzou
    Mark
    Missouri
    Oh and BTW -- I would probably do the same except some dummy (ME) did not leave a un paved path to extend my NG line to my garage. when I get too old and tired of fooling with wood -- I may have him save me a propane furnace -or buy a new small one. I am lucky as I get all of my HVAC stuff thru him at cost.
  8. Jan 24, 2019 at 5:40 AM
    #3228
    Wsidr1
    Indiana
    I got lucky as previous owner, who had the the bldg put up, installed the gas service from the main in the road. He just never ran it inside the bldg. Unfortunately, I suspect his niece who still lives next door and was a lineman for the utility, may have pulled favors to get it installed, because...:
    On my initial inquiry I was told only one gas meter per property deed. Basically, it is the utility being used to ensure only one residence per parcel of land. However, I have already found several properties with bldgs newer than mine with meters on the garages. So, I plan to approach them more forcefully before I run an new line from my house.
  9. Jan 24, 2019 at 2:22 PM
    #3229
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    We supplement with a small propane heater in the kitchen end of the cabin. 250 gallon propane tank, kept as much as 40 - 60% full.
    That little heater can put out some warmth.
  10. Jan 26, 2019 at 6:20 PM
    #3230
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    We had a Vt Castings stove for many many years. Replaced the catalytic combustor once. Didn’t really notice a difference. Replaced it with a Jotul a couple of years ago.
    There is no comparison, even remotely. The Jotul is far more efficient, far cleaner, far less polluting. We used to fill the neighborhood with the lovely aroma of burning wood. Now you’d not even know we burned wood except for the stacks of the stuff outside the house. There is almost no smoke and there is no smell. It all gets turned into heat.
  11. Jan 26, 2019 at 7:30 PM
    #3231
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    We only have smoke rarely. Like when getting it up to temp for the combustor.
  12. Jan 27, 2019 at 12:26 PM
    #3232
    Marc2017toyguy
    Marc2017toyguy Well-Known Member
    Scappoose Oregon
    2016 Tacoma access cab 4x4 Sport
    wheels and tires and side steps
    Here is my wood stove in my shop
    u wish u could ride and Bigmo like this.
  13. Feb 15, 2019 at 1:54 PM
    #3233
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    This never ending string of winter storms has forced me to create a firewood drying rack in my utility room.
    wdb, 2Toyotas and Bigdaddy4760 like this.
  14. Mar 5, 2019 at 12:05 PM
    #3234
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Getting started on the late season refresh with a cord of nicely seasoned deadfall madrona. Feels like summer today but it ain't over til it's over.
  15. Mar 6, 2019 at 5:33 AM
    #3235
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    I like your taste in splitting mauls.
  16. Mar 7, 2019 at 5:21 PM
    #3236
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Thanks, that's the splitting axe, it's paid for itself many times over.
    RocTaco likes this.
  17. Mar 7, 2019 at 5:24 PM
    #3237
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    And then this happened...better get started I guess.
    Bigmo and 2Toyotas like this.
  18. Mar 8, 2019 at 6:13 AM
    #3238
    Noelie84
    Noel
    Wales, Maine
    Sweeeeet.
    Mine's still buried under 2 feet of snow :laugh:
    With the weather we're having here lately, it'll probably be a while before I can start sectioning it up to stove length...
    friendlywithbears likes this.
  19. Apr 9, 2019 at 11:34 AM
    #3239
    Maticuno
    2011 Suburban 2500
    90% green oak. Definitely rubbing the overload spring contact padding.
    Bigdaddy4760 and Noelie84 like this.
  20. Apr 9, 2019 at 11:36 AM
    #3240
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    May have ended stove use for the season yesterday.
    dofartshavelumps likes this.
