Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Nov 8, 2019 at 10:03 AM
    #3481
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    are you not making it into firewood ?
    2Toyotas likes this.
  2. Nov 8, 2019 at 11:12 AM
    #3482
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Yeah. Good question.
  3. Nov 8, 2019 at 1:10 PM
    #3483
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I did that a few times in my youth, but on trees that were much easier to climb like cottonwood.
  4. Nov 8, 2019 at 2:24 PM
    #3484
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Doubtful. We'll have a fair share of it milled; the lower parts are mostly junk, between deadwood/ants & steel (idiots always seem to think that roadside trees are bulletin boards :rolleyes: ), but the upper parts are sound and straight as an arrow, and we know a timber framer who's always looking for long straight wood. And most of them are a solid 24" in diameter, even 20 feet up.
    Our main reasons for dropping them were a combination of age, rot, and proximity to expensive things. For firewood I'd much rather have hardwood; pine burns well but it doesn't last long enough to be much use to me. Mostly the stuff that gets burned will be 'campfire' wood at the camp
  5. Nov 8, 2019 at 3:14 PM
    #3485
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I love doing a frame out of eastern white pine. It's so easy to work, sands quick and hardly any shrinkage.
    Noelie84[QUOTED] likes this.
  6. Nov 8, 2019 at 5:40 PM
    #3486
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Pine will creosote the bejeezus out of your chimney. Only use in small doses.
    markmizzou and 2Toyotas like this.
  7. Nov 8, 2019 at 5:56 PM
    #3487
    Noelie84
    Noel
    Wales, Maine
    Yeah, but only if it's not seasoned first. And it makes great kindling, or a really nice bright pop/snap sort of campfire.
  8. Nov 8, 2019 at 6:11 PM
    #3488
    Noelie84
    Noel
    Wales, Maine
    Grabbed a couple of photos before dark:
    One of them had at least 15 feet of dead core that had been worked over by ants, and it split & shattered when it landed:
    And another one still had so many ants in it that they apparently overwhelmed and killed a gray squirrel that was foolish enough to try to share their tree (that's his tail in that little hollow on the right; the rest was just stripped bones & hair)
    lynyrd3, JeffB and 2Toyotas like this.
  9. Nov 9, 2019 at 10:45 AM
    #3489
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    We're burning hard today.
  10. Nov 9, 2019 at 1:48 PM
    #3490
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I’m still waiting for cold weather so I can use my new stove :pout:
  11. Nov 9, 2019 at 1:51 PM
    #3491
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Well it was 15 degrees here this morning.
    lynyrd3 likes this.
  12. Nov 10, 2019 at 6:20 AM
    #3492
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    24° yesterday AM, I did not look this morning.
    Still warm, sort of.
  13. Nov 13, 2019 at 12:07 PM
    #3493
    ralfnjan
    ralfnjan Well-Known Member
    Touched the door gasket with a piece of wood last night...gasket fell off the door. No fire, had to rely on the Mitsubishi heat pump. Low of -15C, house at 21C this morning. Good to know my "central heat source" (insurance requirement) will keep the house livable. New gasket every 2 years minimum from now on! I checked before first burn, but didn't give it enough of a wiggle I guess.
    STill no word from Pacific Energy about the cracks, but seems to be burning ok. Neither getting larger or migrating outside of door gasket covered area on the front of the stove.
    nDub likes this.
  14. Nov 13, 2019 at 12:10 PM
    #3494
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    My gaskets last longer. What do you use for adhesive? Do you clean and wet when you apply?
    Obviously, you could not place and hold the gasket just for the night???
  15. Nov 13, 2019 at 12:14 PM
    #3495
    ralfnjan
    Tried to tack in place with old Rutger cement, but that's when it fell out in my hands. Cleaned completely this time...wire brush, carbide cone shaped grinder to get to bare metal, then wet and cemented. I took the door off this time so the install went way better than trying to do it with the door hung. The cement tube says dry at least an hour, the teckie I bought it from said leave overnight if you can. Somewhere in between i think. Later this afternoon for a small fire to cure the cement, then usual overnight burn.
    nDub likes this.
  16. Nov 13, 2019 at 12:19 PM
    #3496
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    :thumbsup:
    I lock the door with the cement/gasket to set.
    When I burn, I do a light burn.
  17. Nov 13, 2019 at 3:18 PM
    #3497
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    20F, First fire tonight in my wood burning furnace.
    nDub likes this.
  18. Nov 13, 2019 at 5:36 PM
    #3498
    OZ-T
    Peter North
    British Columbia
    Just replaced the door and glass gaskets for the first time in 10 yesrs with my Pacific Energy Alderlea T5 this year
  19. Nov 14, 2019 at 5:31 AM
    #3499
    Noelie84
    Noel
    Wales, Maine
    Similar here. I replaced what looked like the original the door gaskets on the cookstove I think 3 years ago, when I fixed the door latches, and on the Cellar monster when I installed it in 2013. Both still work like new
  20. Nov 15, 2019 at 5:45 AM
    #3500
    Noelie84
    Noel
    Wales, Maine
    Going with an insert would probably be a more straightforward conversion; my understanding of the Heatilator setup is that they're basically just an insert with a different design anyway?
