Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Nov 21, 2019 at 8:08 AM
    #3501
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Had a light to moderate drizzle the entire day on the range with temps dropping into the low 40's. Very handy to come home to a warm fire and set all my gear out to dry.
  2. Nov 24, 2019 at 4:07 PM
    #3502
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Got the last of my wood. I think I’m set for the winter. Probably just shy of two chords of oak.
  3. Nov 24, 2019 at 5:00 PM
    #3503
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Oh joy. Our oil heater seems to be breathing its last. I was hoping to get one more season out of it but now I'm not so sure. Wood stove only on Saturday morning, now it looks like wood stove only overnight and into Monday. Good thing we have it, and a metric buttload of fuel for it.
    nDub likes this.
  4. Nov 25, 2019 at 3:00 AM
    #3504
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    2 cords is enough? I've burned a cord already..
  5. Nov 25, 2019 at 5:05 AM
    #3505
    nDub
    Lead Free Gasoline
    Should be. Weather is fairly mild here in the foothills of the Sierras. We’ll get into the teens sometimes and see snow every once in awhile but it’s not uncommon to have a sunny day get into the 50s F or more.
    My kids have been wearing shorts right up until recently.
    We are finally getting our first bit of winter weather.
    Maticuno likes this.
  6. Nov 27, 2019 at 4:05 PM
    #3506
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Does anyone have any recommendations for an electric chainsaw sharpener? My dad mentioned that he was thinking of getting one while we were wandering around Tractor Supply, so I thought it would make a good Christmas gift for him.
  7. Nov 27, 2019 at 6:58 PM
    #3507
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Sorry, I'm an analog sharpener, so I can't recommend an electric model.
    Electric sharpeners always seemed like more trouble than they were worth, since you have to take the chain completely off of the saw to sharpen it. Maybe get him a nice clamp-on manual unit instead? There's some nice ones out there that really let you get an evenly sharp clean-cutting saw without obsessively measuring raker height and tooth angles (because they do it for you).
  8. Nov 28, 2019 at 1:49 AM
    #3508
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I like the Pferd, Stihl hand sharpener. Quick, easy, portable, does a good job. Be sure you get one with the right round file size for the intended saw chain, they are different, and you can't change the file size, since they have to fit tight. File size is listed on a Stihl chain box. It also has a flat file, and sets the raker height at the same time.
    I made a jig on top of the toolbox I carry with my MS 250 that holds the saw tight, for easy tailgate sharpening, touch ups, and it's at the right working height. A stump vise is a good alternative, but the stumps I leave are usually too low.
    https://www.amazon.com/STIHL-EASY-C...coding=UTF8&psc=1&refRID=CTX7Q83NP28G6W1AY9F6
    Kolunatic and Noelie84 like this.
  9. Nov 28, 2019 at 6:07 AM
    #3509
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have an attachment for my Dremel. It works great, and I do not have to remove the chain from the saw.
    buyobuyo[QUOTED] likes this.
  10. Nov 28, 2019 at 6:31 AM
    #3510
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    I've never been impressed with sharpening with anything other than my file. Most of my friends feel the same way.
    bigmw likes this.
  11. Nov 28, 2019 at 8:12 AM
    #3511
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    A neighbor is a small engine guy. He uses an electric sharpener, cuz he does a lots of them. He says once he uses the electric, he cannot use another method. I do not know why, but he has never been wrong about anything so far.
    buyobuyo likes this.
  12. Nov 28, 2019 at 8:20 AM
    #3512
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    If it's a grinding wheel style, it cuts a square gullet in the cutting tooth, which while you could probably get it back out with a file it would take forever and eat half the tooth. My biggest problem with an electric sharpener is being in the field and wanting to touch up your chains. It's not unheard of for me and a couple of guys to buck a few cords at once.
    06Tacooo and bigmw like this.
  13. Nov 28, 2019 at 8:35 AM
    #3513
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    The one that they had at TSC looked like a dremel, but it was 12v though.
    Do you know what he uses?
  14. Nov 28, 2019 at 10:34 AM
    #3514
    Scott B.
    Scott
    Georgia
    I use my Dremel in the garage, usually when I clean the saw. I use a file in the field.
    Check this out: https://www.timberlinesharpener.com/
    Really nice - but expensive. Not sure if it is worth it, since I don't run a saw that often.
  15. Nov 28, 2019 at 2:02 PM
    #3515
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    No. I do not.
  16. Nov 28, 2019 at 4:51 PM
    #3516
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Yeah.. I'm not spending that much on a saw sharpener. I can buy a 12 pack of files for like $15.
  17. Nov 28, 2019 at 5:13 PM
    #3517
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Guarantee you the guys in charge
    i almost bought one of those from Lee Valley
    maybe Santa will bring it for me this year
  18. Dec 1, 2019 at 10:51 AM
    #3518
    ralfnjan
    ralfnjan Well-Known Member
    Stihl or Pfred (the makers of the Stihl) 2 in 1 sharpener. After 30+ years of file sharpening it's my only wayt to go now. Fast, accurate, easy to use.
  19. Dec 1, 2019 at 5:21 PM
    #3519
    Scott B.
    Scott
    Georgia
    Link?
  20. Dec 2, 2019 at 7:44 AM
    #3520
    wdb
    Dave
    the perimeter
    plain jane
