Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Dec 26, 2021 at 2:44 PM
    #3881
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I read about using wood ash and water. I do not clean the glass.
    Pibbles99, SH7mi, nDub and 1 other person like this.
  2. Dec 26, 2021 at 3:05 PM
    #3882
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    I use Comet cleanser and a green scotchbrite pad. Go gentle and rinse often to avoid scratches but should be okay.
    12thmanhawkfan likes this.
  3. Dec 26, 2021 at 4:30 PM
    #3883
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Wet paper towel stuck into the ash. Then pretend it’s toothpaste and the glass is plaque.
    Works really well. Might take a couple of paper towels though and don’t try it hot. Or at least too hot, dries the paper towel out too fast.
    Also I’m talking about the inside where the soot builds up. I don’t think I’ve ever cleaned the outside.
    12thmanhawkfan and 2Toyotas like this.
  4. Dec 27, 2021 at 7:42 AM
    #3884
    ralfnjan
    ralfnjan Well-Known Member
    newspaper and water. Messy, but effective. Sometimes scrape with a razor blade if I don't want to wait for cool off. With any wet cleaning wait for the glass to cool enough to touch and keep your hand there.
    2Toyotas likes this.
  5. Dec 27, 2021 at 8:24 AM
    #3885
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Bar Keepers Friend does not use abrasives, so might be a better product that will not scratch.
  6. Dec 27, 2021 at 12:19 PM
    #3886
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Wet paper towel and ash will do ours nicely almost all the time. I follow it with another wet towel for rinse, then a dry one to get it dry enough to squeak.
    When we had a (yet another!) runaway burn last week I gave up and completely covered the secondary burn opening, made sure the fire was completely starved of air, then went up to bed. Window was black in the morning. It's supposed to be self-cleaning so I did a regular burn which got 80% of it off. Used a razor on the rest, then the paper towel + ash thing. Back to new looking.
    Pibbles99 likes this.
  7. Dec 27, 2021 at 2:06 PM
    #3887
    ralfnjan
    Runaway burn? Wood too dry?
  8. Dec 27, 2021 at 4:40 PM
    #3888
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Interesting you said you rent a place and heat it with a pellet stove?
    They must have different insurance laws in AR than in MO. A friend and myself owned a rental property and our insurer said NO WOOD HEAT IN ANY rentals. They even made us take out the wall thimble from a previously installed triple wall flue system!
  9. Dec 27, 2021 at 7:57 PM
    #3889
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The place was in New Mexico, and I rented it from someone. I didn't own it and rent it to someone else.
  10. Dec 27, 2021 at 8:26 PM
    #3890
    markmizzou
    Mark
    Missouri
    I totally understand -- I was surprised your landlord allowed you to use a wood burning device in a rental property. Around here i that is a big no-no, unless the landlord does not care. The insurance policy on the property is invalid if there is a loss
  11. Dec 27, 2021 at 9:57 PM
    #3891
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Hech, he gave me 5 or 10 bags of pellets when I moved in to hold me over until I could buy my own bags. :rofl: The pellet stove was the main source of heat when I moved in. He installed gas wall heaters while I was living there, but I still used the stove to supplement the wall heaters. Pellet stoves are pretty common in NM. I carried renters insurance for my stuff, but I couldn't tell you if he had insurance on the house. His father or grandfather built the house originally.
  12. Dec 28, 2021 at 3:57 AM
    #3892
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Could have been the policy of the insurance company too.
  13. Dec 28, 2021 at 10:30 AM
    #3893
    wdb
    Dave
    the perimeter
    plain jane
    It's an EPA stove with an unregulated secondary burn system. We've had that system run wild a couple of times. I think the culprit is too much draft. I thought about a flue damper but first I'm experimenting with partially covering the secondary burn air inlet. Damn thing is the size of a softball.
  14. Dec 28, 2021 at 10:57 AM
    #3894
    markmizzou
    Mark
    Missouri
    As far as the "newer" "EPA" burn stoves, I have no real time knowledge whatsoever. In my mind, I am wondering if, as you state, letting it "run wild" is bad or good for the system? Older stoves need a real hot burn once in a while to burn out the creosote that can build up. Trouble is if you already have too much creosote buildup -a extra hot burn can ignite the whole creosote build, and you have a flue fire to deal with. Wood burning can get to a tricky balance, which is why I try to burn only year old (or more) really dry wood. Of course, I go thru a lot more wood, but the dryness lowers the creosote build, which is a good trade off in my mind.
  15. Dec 28, 2021 at 11:08 AM
    #3895
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    Is that the T6? Looks nice.
    We have a small Jotul at the old cabin but the new place we are building will require something a little bigger.
  16. Dec 28, 2021 at 12:03 PM
    #3896
    markmizzou
    Mark
    Missouri
    My guess is that the landlord did not have any insurance on the building, or there was no insurance co inspection before the policy was written. Mo. is a very conservative state with the exception of a couple of metro areas, so I doubt if we (Mo.) would have insurance laws that are any different than the nationwide
    standards
    2Toyotas[QUOTED] likes this.
  17. Dec 28, 2021 at 12:05 PM
    #3897
    markmizzou
    Mark
    Missouri
    Nice looking stove!!
  18. Dec 28, 2021 at 12:20 PM
    #3898
    9mmMike
    Michael
    SE PA
    Here is a pic I had handy. This is our Jotul at the cabin. Totally off-grid here. (the switch on the wall is connected to a small solar panel that runs a DC fan when the sun is out and if we turn it on.) The lamp is an Aladdin. There is another one to the left. This is a "typical" end of the day shot. The "boy" in my avatar is on the couch. In that barrel to the right on the stand is some fatwood that I use to start the fire. Ash bucket below that. To the left, out of frame, is a small rack that holds enough wood for a cold weekend. The two tile & wrought-iron stands are used as hot plates. They are touching the stove and get quite warm. Great for keeping the coffee hot. Sorry the pic is so dark.
    SH7mi, 2Toyotas and 12thmanhawkfan like this.
  19. Dec 28, 2021 at 12:26 PM
    #3899
    9mmMike
    Michael
    SE PA
    Hope this pic shows up. From last weekend.
  20. Dec 28, 2021 at 1:16 PM
    #3900
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    T5
    9mmMike[QUOTED] likes this.
