Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Feb 3, 2023 at 5:02 PM
    #4121
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Thanks, you are correct. Not a complete list for sure.
    We do have OO and I usually use it at night for overnight burns when it's available.
    Doesn't come in too often. More locust & varieties of oak available, also cherry, mulberry, tulip to name a few. thumbnail_IMG_2096.jpg
    Put this Empire in last July as part of our home renovations . Three cube box allows for longer burn times.
    Zero clearance high efficiency flush mount fireplace, double blowers, .99 gph more than 4 1/2 times cleaner than the old ZC. Cold air intake. Unit puts out a huge amount of heat. So far longest burn was 10 hours with a combo of OO & oak, three chunks with outside temps in the minus single digits.
    Not bad for a ZC
    Was a bear getting it up 2 flights of stairs. Luckily the installer had an electric motor dolly that lifted the 605 lb unit up one stair at a time.
    I put the blowers on a rheostat & bypassed the snap disc altogether.
    Cement board extends several feet out on each side & nearly up to the ceiling.
    Mantel is above manufacturers recommendation by 9 inches.
    Am looking to install another ZC unit in our retirement home in No. Idaho. My wife cannot abide by a free standing stove & doesn't want a masonry /stone fireplace with an insert.
  2. Feb 4, 2023 at 5:00 AM
    #4122
    ralfnjan
    ralfnjan Well-Known Member
    Those electric dollys are the cat's ass! My last stove in 2009 came down the basement stairs on one. The local rentall has one (he's also a stove dealer) so I rented it for $100 to move out 6 x 450 pound batteries. Not possible without it, and worth the cost of renting. The first stove guy said his cost somewhere around $5K, so he no lend or rent.
  3. Feb 6, 2023 at 3:35 PM
    #4123
    StihlToyota
    Mark
    No. Idaho panhandle
    Mild winter so a head start on the splitting
    Built Rite
    Clark27 likes this.
  4. Feb 6, 2023 at 4:21 PM
    #4124
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Splitter looks like a beast.
    StihlToyota[QUOTED] likes this.
  5. Feb 7, 2023 at 6:27 AM
    #4125
    StihlToyota
    Mark
    No. Idaho panhandle
    15 years old I believe
    100s of cords, original engine, just one O ring replaced
    Very reliable
  6. Feb 14, 2023 at 10:43 AM
    #4126
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I have my hearth mostly built, by the time I have the stove all set up its going to be spring...
    nSb39WN7qPZ7CsNgRSwnpnNsQyq1EDJKNhPZxSe-_254fa48098ad30737713f3ff56fc790c2b4949d8.jpg
    Soonr1, wdb, StihlToyota and 5 others like this.
  7. Feb 14, 2023 at 2:07 PM
    #4127
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
  8. Feb 18, 2023 at 4:45 PM
    #4128
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Actually got a chance to split some wood today
    Hemlock and Fir mix , some free wood from my current job site
  9. Feb 19, 2023 at 6:19 AM
    #4129
    Soonr1
    Soonr1 Well-Known Member
    2022 Army Green TRD Off Road
    I’m just enjoying watching the stove cranking. Damn it’s good to have wood heat again. With the warm weather we’ve had and what is forecasted there may not be many more chances to have it going until late fall. It’s a bummer but Atleast I have it now.
    shift957 and StihlToyota like this.
  10. Feb 19, 2023 at 7:17 AM
    #4130
    StihlToyota
    Mark
    No. Idaho panhandle
    Red oak split with the X27
    Just doodling around until the Spring in-flow starts
    wdb likes this.
  11. Feb 19, 2023 at 5:53 PM
    #4131
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    Just a reminder when tossing firewood in the back of your trucks if you don't have a headache rack... if on a hill, park facing uphill if you can. Otherwise, be really careful, as log rounds will get ya pretty easily...
    You can see there aren't many logs in there, but one took a bounce on the steep slope and hit the pillar and took out 2 of the 3 windows.
    Rain was forecasted later in the week, so I buttoned it up with a quick fix.
    And since cardboard doesn't resist water too well, it got a coat of black paint. That also helped make it less obvious until I got it fixed.
    Got a new rear window through insurance. Safelite did the work and had the new window in in 1 hour after they told me it'd be a most of the day affair. I used the Safelite Auto Glass, but really should have checked into what extra out of pocket I would have had to pay for OEM Toyota glass. OEM is most always better and in this case I think that holds true. (Sorry, no picture of the new glass) it looks fine, but the window doesn't slide as good as the old one and there's an opaque rectangular sticker under the latch, a decent size bigger than the latch, which looks janky IMO. Oh well. Happy Presidents' Day y'all!
    Toyko Joe, StihlToyota and truchador like this.
  12. Feb 21, 2023 at 9:31 AM
    #4132
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I know someone who did exactly the same thing. :anonymous:
    shift957 and truchador like this.
  13. Feb 21, 2023 at 9:35 AM
    #4133
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Has anyone ever installed their own liner? I'm pretty mechanically inclined and videos seem to make it look easy of course. I just wonder what to do at the old fireplace damper door area.
    truchador likes this.
  14. Feb 22, 2023 at 2:16 AM
    #4134
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Is this for a fireplace insert?
    I pulled a flexible ss liner for my new insert a couple months ago. I had to cut the damper and a bunch of firebrick and mortar out of the throat of my fireplace to clear the liner and flue adapter. Let’s just say there’s a reason the insert came with a metal tag indicating the fireplace had been modified to where it would never function again as a regular fireplace lol. Oh well, if I get tired of messing with firewood I can still put a gas insert in there.
    Then I had to bust out the old terra cotta liner to make room for the new liner and insulation
    I rented this (via mail) and it worked awesome https://www.rockfordchimneysupply.com/tile-breaker-and-rods-kit-rental.php
    I also rented a pulling cone from them.
    I used Thermix brand pour in insulation, the other option is to wrap the liner with armored insulation prior to pulling.
    Then I had to recess and run power to a receptacle in the back of the fireplace for the blower.
    There was no way I could fit the elbows necessary in my little fireplace so I went with this to hook the liner to the inserthttps://www.rockfordchimneysupply.com/off-set-box.php
    So it wasn’t easy or cheap but 10/10 I would do it again with the improvement in comfort and economy over the propane furnace that used to run seemingly nonstop this time of year :)
  15. Feb 22, 2023 at 3:59 AM
    #4135
    stevesnj
    Nope it an outset stove.
    truchador[QUOTED] likes this.
  16. Feb 22, 2023 at 4:50 AM
    #4136
    truchador
    Otto
    WV
    15 DC OR
    Nice. It should be a similar process as I went through but you’ll need to decide how much modification to your fireplace is acceptable. Like I said, mine will never be useable as a wood burning fireplace again lol
  17. Feb 22, 2023 at 5:40 AM
    #4137
    stevesnj
    Yeh I found the old damper a few years back from the previous owner and the damper frame hasn't been modified. The videos though never show how to seal the liner at the damper. Dunno why. But I put fireproof wool insulation around the pipe that is there.
  18. Feb 22, 2023 at 8:32 AM
    #4138
    OZ-T
    Peter North
    British Columbia
    bummer
    with my leer cap on I have 3 windows to protect when I'm moving firewood . I cut some plywood pieces that fit the shape of the cap / cab window and side windows and wedge them in there when I'm moving wood . They store beside the woodshed when not in use
    markmizzou and shift957[QUOTED] like this.
  19. Feb 22, 2023 at 9:11 PM
    #4139
    shift957
    Cacapon River, WV
    11 AC OR
    Good call. I have a Trakrak mounted to the bed on each end. I'm thinking something similar to your idea is simple and cost effective. Cut some plywood 2" wider than the width of the rack and attach with u-bolts. Either that or be extra careful....
  20. Feb 23, 2023 at 5:04 AM
    #4140
    BTWNaRock&aHardplace
    BTWNaRock&aHardplace Well-Known Member
    DW
    47°47’47”N 123°41’41”W
    2022 TRD
    a cb radio and 2 baby seats
    can't believe there's a wood heat thread!! It's a lifestyle fer sure. Subscribed
    StihlToyota, Soonr1, stevesnj and 4 others like this.
