Wood Heat Thread ~ post pics
Discussion in 'Garage / Workshop' started by OZ-T, Sep 2, 2012.
  1. Nov 30, 2013 at 7:05 PM
    #441
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    I have a 2 flue masonsry chimney I build i to my house but no fireplace
  2. Nov 30, 2013 at 10:58 PM
    #442
    trailmaker
    trailmaker Well-Known Member
    northern ca
    4wd reg cab
    German, Swiss or maybe Austrian. There are claims that it dries wood faster but I haven't found this to be the case. One advantage is that you can store a lot of wood in a small footprint, useful if you don't have much flat land available. Maybe the practice developed in some part of the Alps where there aren't many level spots for long straight stacks.
  3. Dec 1, 2013 at 8:43 AM
    #443
    motorcycle07
    motorcycle07 Well-Known Member
    Middle of somewhere
    '13 Acc 4X4 V6 TRD Tow
    I have seen people use old car tires to achieve a similar effect as the bungee corded chain did a couple pages back.
  4. Dec 2, 2013 at 5:22 AM
    #444
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Nah, my house had a coal stove in the cellar when I bought it. I ripped that out, swept the flue and had it inspected, and hooked up a woodburner. Did everything but the flue inspection myself, but I didn't have to actually build anything, haha.
  5. Dec 4, 2013 at 6:56 AM
    #445
    Noelie84
    Noel
    Wales, Maine
    Speaking of building things;
    I purchased my current house a year ago. I've been preoccupied with getting it fixed up and livable and now have time for secondary projects.
    I'm going to be building a real actual dedicated woodshed in the spring, once the frost has come back out of the ground. I'm wondering how you all store your firewood, and what the pros and cons are that you've run into with your method of choice (even you, Oz, with your bastardized scaffolding woodshed). For instance, I haven't decided on a solid floor or just stringers; building walls or leaving the sides open, etc. etc.
    So, let's see how you store your wood!
  6. Dec 4, 2013 at 7:17 AM
    #446
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I have a three sided wood shed with a sloping metal shed roof. All three sides are enclosed with the front open. I have a tarp on the ground with furring strips on top of that. I stack the wood on the furring strips, keeps the wood dry and lets air circulate under the wood. The wind never blows toward the open side of the shed, think about the way the wind usually blows in your area before deciding which way to face your shed. Sorry, I have no pics that I can find right now.
  7. Dec 4, 2013 at 7:25 AM
    #447
    OZ-T
    Peter North
    British Columbia
    Go concrete floor if it's at ground level
  8. Dec 4, 2013 at 7:37 AM
    #448
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I went the simple and cheap route, I just laid out pallets on the ground, and for the sides I used concrete blocks with 2x4's slid into them, and over that I slid another pallet. Basically several sets of squares with pallets for sides and floor. I put a wooden roof over all this so the air can blow through but the rain and snow stay off for the most part.
    I think the main thing you want to make sure of is that your shed is facing whichever way the wind most often blows and also max sunlight. The air movement is what does the most to dry the wood out, with sun a close second.
  9. Dec 4, 2013 at 8:32 AM
    #449
    Noelie84
    Noel
    Wales, Maine
    I'm using one of those instant garages right now, with the door facing the prevailing wind and held open. Wood stacked on pallets to keep it off the ground, with 2x4 vertical supports to help hold the stacks up. Still not ideal, though. I was in there the other day and there was 1/2 inch of hoarfrost on the walls and ceiling, since they don't breathe.
  10. Dec 4, 2013 at 8:36 AM
    #450
    Manwithoutaplan
    ID
  11. Dec 5, 2013 at 6:43 AM
    #451
    motorcycle07
    Middle of somewhere
    Currently I store wood to season in a tin lean-to (three closed sides w/ the open side facing east and another structure). I try to cut some small (1"-2") branches to lay down on the dirt/ crushed limestone floor with the wood on top. I then move wood over to the house as needed. With this setup the wood doesn't dry quick enough. I should also mention that I about 8 rows of wood stacked right next to each other. When I went to use wood this fall that had been cut, split and stacked early last winter it was burnable but not quite as dry (especially the slower drying species) as I would like it to be.
  12. Dec 5, 2013 at 7:29 AM
    #452
    OZ-T
    Peter North
    British Columbia
    I never stack wood more than 3 ricks deep , otherwise the it doesn't dry
  13. Dec 5, 2013 at 8:50 AM
    #453
    Noelie84
    Noel
    Wales, Maine
    How long do you cut for your stove length? Mine takes a 24" stick, so I aim for 20-22. But if you're cutting to 16", maybe I should stick to two ricks deep in the future...
  14. Dec 5, 2013 at 9:11 AM
    #454
    OZ-T
    Peter North
    British Columbia
    I usually cut 16-18"
  15. Dec 6, 2013 at 6:38 AM
    #455
    motorcycle07
    Middle of somewhere
    So I have discovered. I am somewhat short on space but will make improvements in the future. Hopefully to a more open air structure.
  16. Dec 6, 2013 at 7:46 AM
    #456
    OZ-T
    Peter North
    British Columbia
    IDK if you saw my scaffolding woodshed idea at the beginning of the thread but any similar simple structure will work , I like to look at my wood supply as a 2 year system , wet wood sits in the scaffold woodshed at the back of my property for a season , then the next summer I move it to the woodshed by the house for use
  17. Dec 6, 2013 at 8:41 AM
    #457
    Noelie84
    Noel
    Wales, Maine
    I'd like to have my woodshed large enough for that as well. I lack one connected to the house, but I have enough space in the back yard to build large enough for a two year supply. Then I can just alternate which side I pull from year to year. I've got next year's supply cut to length already, but it's just stacked and under tarps. I'd much rather have it split, off the ground, and under cover so that it can do some actual drying rather than just end-checking.
  18. Dec 6, 2013 at 8:53 AM
    #458
    OZ-T
    Peter North
    British Columbia
    Yeah , even just splitting it helps , lots of people here just split the wood and stack it and maybe put a piece of plywood on top or even just put the bark side up on the top row for a season , then into the woodshed the next summer
  19. Dec 10, 2013 at 6:59 PM
    #459
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Has anyone ever tied a wood furnace into a HVAC system?
  20. Dec 10, 2013 at 7:01 PM
    #460
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Are you sure you don't drink?
