Woolwax (fluid film) This Fall 2020 Multiple days
Discussion in 'North East' started by jpereira2, Aug 16, 2020.
Regaular Clear(straw) or Black woolwax for my next order. Prices will go up with black
Poll closed Nov 9, 2020.
  1. Clear (straw)
    9 vote(s)
    45.0%
  2. Black
    11 vote(s)
    55.0%
  1. Aug 27, 2020 at 6:32 PM
    #41
    jpereira2
    jpereira2 [OP] Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Bahaha ok sweet see you then
  2. Aug 29, 2020 at 5:15 AM
    #42
    slapshotcs30
    slapshotcs30 Member
    Westwood, MA
    2019 TRD Off-Road Double Cab
    No problem
  3. Aug 29, 2020 at 11:07 AM
    #43
    jpereira2
    Massachusetts
    Added Sunday the 6th if that works for you?
  4. Aug 30, 2020 at 1:45 AM
    #44
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've been meaning to try WW. I need to use up my 2 gallons of FF first.
    GQ7227[QUOTED] likes this.
  5. Aug 30, 2020 at 4:45 AM
    #45
    Steevoreeno
    Steevoreeno Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
    Can I get in on Sunday the 6th for $40 please?
    jpereira2[OP] likes this.
  6. Aug 30, 2020 at 5:06 AM
    #46
    Capespencer68
    Capespencer68 Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    I’ll be in touch.
  7. Aug 30, 2020 at 8:53 AM
    #47
    jpereira2
    Massachusetts
    Probably the same height. I've got the plastic rhino ramps. And yes I get neck and muscle strain every time
    Yes sir
  8. Aug 30, 2020 at 9:15 AM
    #48
    GQ7227
    GQ7227 mw survivor
    J A Y
    ... doing some more DD on the woolwax product and found this offering to use in cavities such as doors,rockers,tailgate,inner frame, etc. that likely does not see a large amount of roadspray
    are you also using this product that supposedly has a lower viscosity 'thinner' such as that FF stuff has?
    https://www.woolwaxusa.com/Woolwax-LV-Cavity-Wax-5-Gallon-Pail-_p_54.html
  9. Aug 30, 2020 at 10:31 AM
    #49
    jpereira2
    Massachusetts
    No I do not. I don't spray inside the doors, tailgate. I strictly spray in the frame rails with the hose, the outside of the frame, and the underside of the vehicle
    Capespencer68 and GQ7227[QUOTED] like this.
  10. Aug 30, 2020 at 10:34 AM
    #50
    jpereira2
    Massachusetts
    @GQ7227 I should also state I recently installed all new speakers and sound deadening and there was no corrosion to be found in there either after 7 years
    GQ7227 likes this.
  11. Aug 30, 2020 at 11:39 AM
    #51
    jpereira2
    Massachusetts
    Hmmm I haven't seen tailgates rotting. I'm sure some of it depends on how much the truck is used as a truck. Mine doesn't do much bed duty lol, I've got a cap on it
  12. Aug 30, 2020 at 7:02 PM
    #52
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    I bought 5 gallons of Woolwax and it came with a few spray cans for using in those areas.
  13. Sep 2, 2020 at 8:34 AM
    #53
    GQ7227
    GQ7227 mw survivor
    J A Y
    i just bot a gallon of this WW product, have you used it on anything on your rig?
  14. Sep 2, 2020 at 8:40 AM
    #54
    jpereira2
    Massachusetts
    I have not. Since this is an even thicker product, does it still get sprayed on? or is it more of a brush on product?
  15. Sep 2, 2020 at 8:41 AM
    #55
    GQ7227
    GQ7227 mw survivor
    J A Y
    they told me it was a brush on for leaf springs and the other very high splash areas
  16. Sep 6, 2020 at 6:05 PM
    #56
    jpereira2
    Massachusetts
    Updated
  17. Sep 7, 2020 at 12:26 PM
    #57
    jpereira2
    Massachusetts
    Just ordered another 5 gallons. Did 8 trucks yesterday and have enough for a few more but ordered before I ran out. I'll be adding some more dates soon.
    GQ7227, Capespencer68 and koditten like this.
  18. Sep 12, 2020 at 7:18 AM
    #58
    jpereira2
    Massachusetts
    More woolwax came in! Should be good for the rest of the season.
  19. Sep 12, 2020 at 7:23 AM
    #59
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Other than the exhaust, is there anything you are avoiding spraying? Electrical connections, etc?
    GQ7227 likes this.
  20. Sep 12, 2020 at 7:29 AM
    #60
    jpereira2
    Massachusetts
    Nope, and a little overspray on the exhaust isn't an issue. Some people want the underside of the body sprayed and the rockers and I typically do that as well including on mine. Also drop the spare tire for more access
