WORKING ON THE 3VZ-FE 3.0
Discussion in 'Off-Topic Discussion' started by 92dlxman, Aug 5, 2013.
  1. Aug 5, 2013 at 8:57 PM
    92dlxman
    92dlxman [OP] drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I think that's what its called anyway. . . .the only other multi-cylinder motor I ever got into was my old 22re. this is on my neighbor's 95 Toyota pickup. NOT Tacoma!
    anyways, we are replacing both head gaskets on this beast and was wondering if anyone had any pointers. this is an auto transmission also so I imagine I will be fabbing a few different "holders" for cams and crank at least
    we almost got the plenum off tonight, trying to find a couple more things holding it together. we'll get there
  2. Aug 6, 2013 at 10:30 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Hey man, :)
    What helps me on disassembly projects is to put all of the removed parts and their supporting hardware in one box and make sure that when you're done, the box is empty. I especially like to use those magnetic metal dishes because the nuts and bolts stick and don't get lost. :thumbsup:
    Greg
  3. Aug 7, 2013 at 7:14 PM
    92dlxman
    Kevin
    Visalia, CA
    thanks man!
    Im being super careful since its not mine. I feel bad already as I have run him 150$ over what I guessed he would spend in parts. . . . and we don't even have head-bolts yet lol
  4. Aug 8, 2013 at 10:01 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Make sure you install the gaskets On the right sides, they look very similar but one side has a small hole that the other side doesn't
  5. Aug 8, 2013 at 10:25 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That engine is prone to head gasket leaks. You have to have a real smooth surface on the heads and the block or else it will fail again. Also since you're in there, replace the knock sensor and connector.
  6. Aug 8, 2013 at 10:34 AM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    If i remember correctly, think i pulled both heads together as one unit to avoid fighting the rear exhaust crossover pipe. Intake manifold probably also.
  7. Aug 8, 2013 at 3:17 PM
    92dlxman
    Kevin
    Visalia, CA
    right on thanks guys! keep it coming!
