Workout questions? Ask a Bodybuilder/Personal Trainer
Discussion in 'Health' started by Morrison, Apr 5, 2011.
  1. Aug 12, 2011 at 10:55 AM
    #261
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i thought everyone did?
  2. Aug 12, 2011 at 10:56 AM
    #262
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Now that you guys got the sand out, answer my question:
    When you take creatine, do you take it straight (powder/pill) or flavored mix? Also do the sales pitches for increased absorption/transmission really work?
  3. Aug 12, 2011 at 11:35 AM
    #263
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Here's MY experience:
    I used to take it In powder form as liquid is absorbed faster (?) but would get bloated and headaches. Last year I started kre-alkalyn (purple pills) by EFX. No bloating, no headaches, and kept strength relatively high during prep. If u go this route male sure you are on liver care and then liver fix after the cycle.
  4. Aug 12, 2011 at 11:38 AM
    #264
    PLC721
    Patrick
    Chandler, Az
    What's liver care and fix?
  5. Aug 12, 2011 at 11:46 AM
    #265
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    This. And turn auto-correct on (I know your'e on your phone.) You speel bad.
  6. Aug 12, 2011 at 12:17 PM
    #266
    T-Rex266
    Elon
    What's wrong with my spelling?
  7. Aug 12, 2011 at 12:19 PM
    #267
    PLC721
    Patrick
    Chandler, Az
    I think that was directed towards me?
  8. Aug 12, 2011 at 12:20 PM
    #268
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Maybe its your grammar. What is Liver care?
  9. Aug 12, 2011 at 12:23 PM
    #269
    T-Rex266
    Elon
    Liver care supports your liver function and liver cell integrity. Liver fix, detoxifies the liver (?) and also supports a healthy liver.
    On a side note, I apparently wasn't taking enough of both and have had ALT counts all fugged up. Take the support a few times a day and cycle the kre-alkalyn.
  10. Aug 12, 2011 at 12:24 PM
    #270
    T-Rex266
    Elon
    Perhaps; when I'm using my phone I'm not as careful as I should be with grammar.
  11. Aug 12, 2011 at 12:31 PM
    #271
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Do you have to do a Load phase with the Kre-alkalyn?
  12. Aug 12, 2011 at 12:50 PM
    #272
    T-Rex266
    Elon
    No, it's not a like a ph
  13. Aug 12, 2011 at 12:56 PM
    #273
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Would you recommend a creatine supplement for someone like myself, that is building more endurance? Say for instance if I only took it two times a week, after my hardest work outs?
  14. Aug 12, 2011 at 12:59 PM
    #274
    T-Rex266
    Elon
    Honestly, I'm not sure if it builds endurance(?) but, if you do take it take 1 am and 1 pm on your off days. On your weight training days take 1 pre-workout and 1 post-workout.
  15. Aug 12, 2011 at 1:15 PM
    #275
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    I did two cock push ups before my PT test this morning!
    edit: motivated me to run a 13:39 2 mile. A minute an 9 seconds from my goal...guess I should do more cock push ups.
  16. Aug 21, 2011 at 11:40 PM
    #276
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    question, you can pm the answer if you want, when training for high endurance/strength is it best to have a set routine of IE x amount weight 3 sets of 10, or 5sets of 5, 3 set of 15??? ect... or bump up the weight each week and go to failure?
    mainly for a firefighter agility test but i wanna add muscle mass at the same time, i eat and sleep appropriately for muscles to actually recover, and also do a crossfit style routine tues thurs and fri
  17. Aug 22, 2011 at 1:08 AM
    #277
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    10 sets of 10 compound exercise, then 3 sets of 10 isolation. No need to go to failure unless its abs or core. Being your size and weight, failure is not gonna help with mass.
    If you're doing 5x5 you should be doing heavy weights and pumping the weight up each week. You can bump the weight up with 10x10 as well but after about 6 weeks of the 10x10 you'll cut back to 6x10 with higher weights.
    Or continue with crossfit, only more times per week.
    What endurance are you looking for to better yourself for the test? Cardio endurance? Muscular endurance?
    I noticed you said agility, think stretching also.
  18. Aug 22, 2011 at 6:35 PM
    #278
    JML50
    JML50 Well-Known Member
    When doing ab workouts on machines, is it better to use a small or moderate amount of weight and do alot of reps or heavy weight with a few reps (8-10)?
  19. Aug 22, 2011 at 7:34 PM
    #279
    KodiakToyTRD
    CO
    Moderate weight x high rep for core strength. Heavy weight x moderate rep for size.
    Don't forget to mix in hanging leg raises, knees to elbows etc for core and lower abs being as most ab machines just work the upper abs area.
  20. Aug 22, 2011 at 8:21 PM
    #280
    T-Rex266
    Elon
    I do 5x25 lower 5x25 upper various exercises.
