Workout questions? Ask a Bodybuilder/Personal Trainer
Discussion in 'Health' started by Morrison, Apr 5, 2011.
  1. Jan 22, 2012 at 4:11 PM
    #321
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I would focus mainly on strength as endurance, not so much. There are many FF and LEO on this thread that I'm sure will chime in on what they recommend. But, my suggestion would be
    Mon- quads, hammies, calves, abs, cardio.
    Wednesday- back, traps, triceps, shoulders
    Friday- chest, biceps, shoulders, abs, cardio.
  2. Jan 22, 2012 at 5:48 PM
    #322
    CNEDEER
    CNEDEER If ya ain't first, your last!
    2015 DC TRD OR 4x4
    Number of reps and sets? What do you think?
  3. Jan 22, 2012 at 6:00 PM
    #323
    T-Rex266
    Elon
    Since your focus is on endurance, I recommend as heavy as possible, short rest periods 15-20reps
  4. Jan 22, 2012 at 6:00 PM
    #324
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Meth...
  5. Jan 22, 2012 at 6:00 PM
    #325
    T-Rex266
    Elon
    Diet/cardio
  6. Jan 22, 2012 at 6:02 PM
    #326
    CNEDEER
    2015 DC TRD OR 4x4
    I thought for heavy sets, it was high weight, less reps?
  7. Jan 22, 2012 at 6:09 PM
    #327
    T-Rex266
    Elon
    Why cut coffee out? Just cut the creamer and sugar. I use liquid stevia or sf creamer.
    Have you tried HIT cardio? It's probably more effective for fat burning, endurance, and would be much easier on your knees.
  8. Jan 22, 2012 at 6:12 PM
    #328
    T-Rex266
    Elon
    Why less reps? The more you can push the better. More reps equal more cals burned, more muscle fibers being used and more stress thus creating better cardio vascular levels overtime correct? Honestly,pat of my reps might be 12,10,8,8 or 20,15,15,12. Everything works differently for everybody. You need to do what works best for you and start slow.
  9. Jan 22, 2012 at 6:18 PM
    #329
    CNEDEER
    2015 DC TRD OR 4x4
    IDK, in high school we did, 5 5 5, 3 3 3, 5 3 1, 10 8 6. etc. And do you reccommend these for like the major lifts bench, squat, etc.. Or even workotus with dumbells as well?
  10. Jan 22, 2012 at 6:20 PM
    #330
    PLC721
    Patrick
    Chandler, Az
    i go as heavy and as long as i can go
  11. Jan 22, 2012 at 6:38 PM
    #331
    T-Rex266
    Elon
    The key is variety. Not only will this help with boredom, but it'll keep the mind and body confused. I rotate db and BB and my rep ranges monthly. Rest periods are always short to keep my endurance up,and fat burning in high speed mode.
  12. Jan 22, 2012 at 6:43 PM
    #332
    CNEDEER
    2015 DC TRD OR 4x4
    Gotcha. What would you recommend rest periods wise? 30 seconds?
  13. Jan 22, 2012 at 6:45 PM
    #333
    T-Rex266
    Elon
    Ur goal is endurance right? If so, 30-45secs
  14. Jan 22, 2012 at 6:54 PM
    #334
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Alex,
    Could use some advise...First, I'm no spring chicken. In 20's, was 5'9 and 200 lbs and less than 10% body fat. In 30's and 40's I ran 30-40 miles a week. Over a 15 to 20 year period, lost a good deal of bulk but still was no lightweight at 185 lbs. and still less than 10% body fat. My joints don't do well with the running anymore so gave that up. I'm back up to 195 and my body fat is over 20% and I've gained 2-3 inches around the waist. My problem is I keep tweaking my lower back (L4 and L5 area). Tweaking is defined as I bend in a normal way, doing something normal (not lifting anything) and I feel a sharp pain.
    I've gone to an orthopedic who says bone, vertebrae, and discs look excellent, particularly for my age. It used to be I’d tweak my back and be out of commission for a few weeks at a time. I’ve improved my situation. Now when I tweak my back it’s never bad enough to keep me from walking but it’s painful for the first mile or so. I usually can’t do anything else for the next 3 to 5 days. What I’m looking for some advice with is how I can build strength in my lower back so this doesn’t happen at all.
    My routine, for several years, has been I walk (~4 miles) 5-7 days a week with a 40 lb weight vest. For the past 2 years I’ll do 500 sit-ups daily on a situp bench. (The bench has the seated part at ~45 degrees, butt lower than knees, with ankles locked behind a bar.) My range of motion is probably a little less than 90 degrees. For the past couple of months (in an attempt to build lower back strength) I’m doing sit-ups with resistance. I have a weight machine where you sit in virtually the same position as the sit-up bench but there are straps you grab with both with each hand. The straps come over my shoulders and I hold them at the center of my chest. The straps are connected to a weight stack. As you pull forward, you raise the stack. As you go back, you lower the stack. I’m doing 200 reps with 50 lbs. In addition, I do 2 sets of bench presses (20 reps first set, 15 reps second set), arm curls, and upright triceps extensions. I do all my weight lifting these days on my machine (weight stacks) to keep from tweak my back. The last thing I do is hang on an inversion table to stretch my back.
    Like I said, my back has gotten better. I don’t tweak it as often and when I do hurt it, the pain is not as debilitating and it doesn’t last as long. Is there anything I can do strengthen my back so I don’t hurt it anymore? Any suggestions would be appreciated.
    Thanks in advance.
  15. Jan 22, 2012 at 6:56 PM
    #335
    saf023
    East Coast
    After looking, it doesn't appear the OP has been here in a while...
  16. Jan 22, 2012 at 6:59 PM
    #336
    T-Rex266
    Elon
    Deads, rack deads, hyper extensions.
  17. Jan 22, 2012 at 7:13 PM
    #337
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Try some stiff legged deadlifts for lower back, and keep up th ab/core exercises, ad some rope cruches as well.
    I have had back issues over the years, but you have to train through your injuries best you can.
    A good chiropractor can work wonders. My experience with MD is all they do 4 u is give muscle relaxers or in woorse case, surgery.
    Anyone can trim fat and do it fast if they are doing regular workout/fitness routines, just up your protien, cut carbs and drink lots of water throughout the day, water is key to fat loss. goodluck, Kimo
  18. Jan 24, 2012 at 10:25 AM
    #338
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    anyone have a geraat split routine that they swear by? could be a four or five days split. Thanks!
  19. Feb 12, 2012 at 4:20 PM
    #339
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Any thoughts/opinions on DHEA?
  20. Apr 20, 2012 at 7:55 PM
    #340
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    During the last few years I've been in and out of some half-assed workout routines. Never did any during high school (was home-schooled), did some during the time I was working for the Dept of Corrections, now I'm just doing it to keep from getting fat.
    I've noticed that during a workout, it always feels like I've exercised my right side more than my left. No matter how hard I try to make things consistent, it always feels like it's easier to work my right side and always feels like the right side has been worked more. WTF? It's driving me nuts.:confused:
