worn out steering rack
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoNinja12, Feb 12, 2011.
  1. Feb 12, 2011 at 8:41 AM
    TacoNinja12
    TacoNinja12 [OP] Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    my 99 2.7 has a worn out steering rack. anybody know if you can rebuild it or if its just easier to buy a new one. i found one at trail gear for 399. and some on google shopping for like 250.
  2. Feb 12, 2011 at 1:53 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Replace, no rebuilding.
  3. Feb 12, 2011 at 2:20 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Just replace it with another oem rack.
  4. Feb 13, 2011 at 8:03 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You sure it's the rack, or just the bushings? I replaced my steering rack bushings with polyurethane one's and it's good as new now. Lot cheaper than a new rack too.
  5. Feb 13, 2011 at 9:59 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    The seals were gone in mine and the passenger side boot had 2 quarter sized hole in it pouring fluid costing me around a quart every 2 days so i replaced the whole rack and both outer tierods for 320, install myself.
  6. Feb 15, 2011 at 9:00 AM
    TacoNinja12
    Boone NC
    99 2.7L SR5
    3 inch lift
    So if I don't fix this for a while how will I be affected? Will I die or just have loose steering?
  7. Feb 15, 2011 at 10:32 AM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    just keep toping it off and you should be fine till you can fix it, irode with mine leaking for 4-6 months just had to add fluid like crazy and it finally got so bad to where i was using a quart a day, but just dont let it go dry or it will screw your PS pump up to
