Worn throttle body shaft fixes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pickeledpigsfeet, Nov 20, 2017.
  1. Nov 20, 2017 at 2:30 PM
    Pickeledpigsfeet
    Pickeledpigsfeet [OP] Well-Known Member
    Foothills, CA
    i have a 98 5vze with 200k on it. Started having high idle issues. Cleaned then replaced iac with no change. Read a thread about worn shafts. While idling I can pull out on shaft and the idle drops to normal. So i shim it with a washer and now everything is back to normal.
    I am thinking about a better longterm fix than the washer. Anyone have any luck with a shop boring and using bronze bushings to get the TB shaft to seal up? I am thinking about just looking for a replacement TB and hoping it doesnt have the same issue.
  2. Nov 20, 2017 at 2:40 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    There is a guy on here who had his TB rebuilt by a shop (in Florida iirc), they made a new custom sized valve plate and shaft for it to fix a high idle, did a really nice job.
    Not that helpful, but I know it's been done. I'll look around and see if I can find the thread.
  3. Nov 20, 2017 at 4:39 PM
    Pickeledpigsfeet
    Foothills, CA
    Thanks, sounds like what I need. I will try searching again.
  4. Nov 20, 2017 at 4:52 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
  5. Nov 21, 2017 at 8:17 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
