Worn tires front or rear?
Discussion in 'Wheels & Tires' started by BeachBoy, May 20, 2018.
  1. May 20, 2018 at 11:22 AM
    BeachBoy
    BeachBoy [OP] Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    I am putting my summer tires back on and one pair (that was in the back) has more thread than the ones that were in front.
    Should IlI put the tires that are most worn in front or rear?
  2. May 20, 2018 at 11:50 AM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    Worn tires in front, less tread in the rear will turn your truck into a tree magnet in slippery conditions.
    BeachBoy[OP] likes this.
  3. May 21, 2018 at 8:15 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    For optimal wet handling, the tires with less tread depth should be installed in the front.
    MolonLabeTaco likes this.
  4. May 21, 2018 at 8:28 AM
    IowaTaco
    IowaTaco Well-Known Member
    Zach
    Central Iowa
    2018 Quicksand TRD Off Road
    New tires in the rear. The shop I worked at in college would make you sign a waiver if you wanted the new tires on the front, and there were other shops that would flat out deny service if you wanted new tires on the front instead of rear.
