Worried Dealer Put Wrong Fluid in Transfer case/Transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacodactylNW, Aug 30, 2022.
  1. Sep 12, 2022 at 11:57 AM
    TacodactylNW
    TacodactylNW [OP] Active Member
    Nick
    Washington State
    2020 Red TRD OR
    Front: Bilstein 5100s Ebach pro 2in Rear: Bilstein 5125s AllPro 3inch expedition, timbren bump stops, SS extended rear brake lines, Ubolt flip Leer RCC100 Roofnest Condor Xl Prinsu topper rack RCI skids and sliders Total Chaos bed stiffeners
    It’s taken me a while to get to this but here’s an update. Called the dealer they told me they replaced the fluid in both the transfer case and the transmission said they didn’t know about the fluid type.
    Decided to change both just to be safe. Transmission drained super clean but smelled strong like diff fluid. There was also a lot of fluid either spilled and not cleaned or leaking from fill plug. T-case looked slightly dark like maple syrup didn’t smell nearly as much. So thinking they didn’t change that. Really gives me a lot of confidence in the “professionals”
    definitely seems like it’s shifting a lot smoother now that the fluid is correct.
    JJ Diablo likes this.
  2. Oct 22, 2022 at 12:36 PM
    TacodactylNW
    Nick
    Washington State
    2020 Red TRD OR
    Decided to send in a sample of the questionable oil in the transmission to Blackstone for testing will post the results once I get them. Hoping they will be able to tell me if its GL4 vs GL5 new to lab testing of oil so I'm not sure.
  3. Oct 22, 2022 at 12:52 PM
    Bishop84
    Bishop84 Well-Known Member
    It's going to be 75w90 GL5. 100% Every dealer does this. GL5 is compatible and is not an issue. TW makes a big stink about this all the time.
    Most tacomas have GL5 in the transfer case after a service. It doesn't hurt anything.
    I can say I've never put GL4 in a transfer case in my career. Only now the new models actually specifically request LX or LT fluid.
    TacodactylNW[OP] likes this.
