Worse mpg followed buy dreaded p0430 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by desertrunner24, Jan 13, 2018.
  1. Jan 13, 2018 at 7:16 PM
    desertrunner24
    desertrunner24 [OP] Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I have noticed that my last 2 fill ups my mpg have gotten considerably worse, about 230 m.p.t. Today I noticed a slightly rough idle and after driving a few miles my check engine light came on. No loss of power or anything, still runs normal. Drove home and put it on the scanner and pulled up the p0430 code and have been researching it for hours. I plan on replacing the downstream o2 sensors and pcv valve. I just completed a tune up a of plugs, maf, and t.b cleaning. Also changed water pump, radiator, thermostat, fan clutch, and coolant at 100k. Truck not sits at 104k. Any help would be much appreciated as I don' want to throw parts at it and not solve the problem. Thank you in advance
  2. Jan 13, 2018 at 7:26 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Why did you changed water pump, radiator, thermostat, fan clutch...at 100k? Had any failed or was this for fun?
    Quick google says likely catalytic converter
  3. Jan 13, 2018 at 7:27 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Leaking water pump. I just don't see a cat going out a 100k
    Edit. I installed headers at 90k and cleaned monitored cats while I was at it. Everything looked good.
  4. Jan 13, 2018 at 7:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Without some scan data and an understanding of what sets p0420/430s, throwing parts at it is really your only option for figuring this out..
  5. Jan 13, 2018 at 8:15 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I went through all the live streams and all I found was 1 misfire on #6. I also went through injectors and manually cut fuel to them to test functionality. I guess I'm just hoping it' not the cats. Don' want to fork out the non existent funds for them if they are not the problem.
  6. Jan 13, 2018 at 8:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Can you feel the miss while driving? Does the CEL flash?
  7. Jan 13, 2018 at 8:23 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    i can only feel it at idle. It's not really a miss it's just a minut rough idle. And no flashing mil. First time it has ever come on was today
  8. Jan 13, 2018 at 8:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Other than an exhaust leak the only thing that will set a cat code is a bad converter. Be careful though, if there is a misfire (slight, intermittent or otherwise) the raw fuel that goes down the exhaust is what takes out converters. If money is tight, hold off on the cat for now, make sure your plugs and coils are good (no mis-fires at all) and then get a new cat. Also beware of cheap converters. They skimp on the catalyst material to keep costs down and they will set codes again..
  9. Jan 13, 2018 at 8:33 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If you go aftermarket cats, go Magnaflow...2nd best to OEM. I just replaced mine after a P0420 code that wouldn't go away, took care of the code and they were $600 out the door. Toyota cats would've been closer to $2k for both, granted I don't expect the Magnaflows to last nearly as long but you get what you pay for when it comes to cats.
  10. Jan 13, 2018 at 8:43 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Yeah I am aware of cheap cats. Oem or magnaflow. I was unaware that magnaflow made CA compliant cats though
  11. Jan 13, 2018 at 8:48 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    P0430 is bank2 which is driver's side. Since your only getting one code, try swapping the sensors side to side and see if the code changes to bank one. If it stays the same, it could be the cat.
    desertrunner24[OP] likes this.
  12. Jan 13, 2018 at 8:51 PM
    eon_blue
    Azusa, CA
    They do. I just passed smog after getting mine put in
  13. Jan 13, 2018 at 8:51 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Haven't thought about that:annoyed:. Thanks for the reminder.
  14. Jan 13, 2018 at 8:53 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Did you get the federal ones? Their web site said they dont carry CARB legal
  15. Jan 13, 2018 at 8:56 PM
    eon_blue
    Azusa, CA
    They were definitely CARB legal...the smog shops here can't put non-CARB ones in per state regulations...our so I was told. At any rate I passed smog for another 2 years so I'm happy lol
  16. Jan 13, 2018 at 8:58 PM
    Stefan_Ray
    Stefan_Ray Tacoma TRD Life
    Stefan
    Concord,North Carolina
    2021 TRD Pro
    Cooper STT Pro’s
    What year is your truck? There was a recall for the Cats in ALL 2016’s.
  17. Jan 13, 2018 at 9:01 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    06
  18. Jan 13, 2018 at 9:01 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
    Buy Cataclean and follow instructions.
  19. Jan 13, 2018 at 9:03 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Does that stuff really work? Or is just a gimmick? I feel I would be better off using mineral spirits lol.
  20. Jan 13, 2018 at 9:09 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    lol I used it on my girlfriends truck and it worked.
    I reset the code a few times and it kept coming up. Was going to use Lacquer Thinner, but my girlfriend was sketchy about it. So I bought Cataclean and ran roughish till it was done running threw the tank, but the code never came back. I can't remember if I reset the code or if it went away after the Cataclean by it's self though. I mean $25 vs new cats worth a shot.
