Worst accessory sold with the truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leggo, May 13, 2012.
  1. Oct 15, 2012 at 9:44 PM
    #161
    Leggo
    Leggo [OP] slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I have never used the bed outlet because I don't have anything that draws that low amperage that I need to use. Can it be wired for higher amps rating?
  2. Oct 16, 2012 at 7:44 PM
    #162
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I have actually heard some really great systems, including the system I had installed in a car of mine years ago. For a OEM upgraded system in the price range that the Tacoma is in the JBL system actually sounds pretty good. You can't compare it to an aftermarket system.
  3. Oct 16, 2012 at 7:54 PM
    #163
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    The 2012's do that. You should check if they will fit in yours.
  4. Oct 17, 2012 at 10:26 AM
    #164
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Mine came with the Toyota bug guard hood protector. After seeing how it was mounted i removed it, sawed it up in little pieces, and threw it in the trash. :mad:
  5. Oct 17, 2012 at 10:32 AM
    #165
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Hated the Toyota bug guard hood protector the way it mounts is just stupid.
    I use my bed outlet to power the lights to our vendor tent when I go on vacation don't need my crappy generator anymore.
  6. Oct 17, 2012 at 10:57 AM
    #166
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Agree....dumbest engineered POS along with the cheap a$$ rubber they pass off as tires
  7. Oct 17, 2012 at 11:37 AM
    #167
    ANoodle
    ANoodle Active Member
    Adam
    Livermore, CA
    2012 4x4 SR5
    Stock for now.
    Worst thing was the tires that come with the new truck, Dunlop AT-26. Why woudl you put on a street tire, they are truck and need truck tires. You would figure spending 30-35K on a mid-size truck they would at least put something decent on the wheels.
    Everything is ok with me even if you dont use it.
  8. Oct 17, 2012 at 12:28 PM
    #168
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    I preferred the steering wheel in my '05 Sport over the new one in my 2012 Baja. The 2012 is identical to the one in my 2010 4Runner TE, so you know they decided to save costs by sharing parts. It has some tight spaces that my fingers get stuck in during a quick, full rotation.
    - I got the Baja, so I like my stock tires and factory lift. That'll likely be all the lift it ever sees. I like the TRD cat-back too. I know some don't.
    - I ordered the OEM skidplate from dealer. I just like the way it looks. It would collapse under any strain. The mounts are flimsy.
    - I ordered Tacoma all-weather mats from the dealer. I know I could get weather-techs (had them in 4Runner), but these say "Tacoma" and look more authentic.
    - Baja stickers are worthless to me.
    - I have used the bed outlet on more than one occasion. Even powered an electric chainsaw with it once. I was surprised it handled that.
    - I took all three rear headrests (its a DC) out while still in the dealer parking lot. They will collect dust in my closet now.
    - The plastic mudflaps WILL crack off after a winter or two of ice build up. Happened on my '05. I may leave them on the Baja until it happens. Dunno yet.
    - My Baja came with Tacoma door still protectors. They look like tape. Too soon to tell if they actually protect anything.
    - I LOVE the JBL system. Turn the bass down one or two clicks, leave the mids at dead center, plus one click for the highs and crank it up! Default settings are too boomy for my taste.
  9. Oct 17, 2012 at 12:40 PM
    #169
    4ST EYES
    4ST EYES New Member
    sault ste marie, ontario
    2009 Tacoma TRD off road
    The first thing I did was rip out the centre console in between the rear seats and put in a sheet of plywood to make a level area for my labrador. My 07 didn't have it but the 09 does. I also could have done without that monsterous sub-woofer also. When I want my wheels to bounce I'll go for a "drive".
  10. Oct 17, 2012 at 1:10 PM
    #170
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    I agree.
  11. Oct 17, 2012 at 1:28 PM
    #171
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    ^^^^^What they should have done is made the whole thing a power vertical sliding window! That, I would pay for.
    People complain about the JBL system but I think it sounds fine. the EQ controls could offer better sound shaping and the subwoofer needs it's own volume control, filter and EQ of it's own but all in all, I think it's a great sounding system. Yeah sure, I'd rather have a couple McIntosh amps and some Martin Logan electro-statics in there, but that's never going to happen.
    and also, people complain about the strength of the tailgate...I weigh close to 300lbs and I've stood on the very very edge of my tailgate while it was down holding very heavy objects and never felt anything but a solid tailgate under my feet...what on earth are you people doing to your tailgates? It's possible that I just don't do things other people do with their trucks (i.e. haul atv in the bed, etc).
  12. Oct 17, 2012 at 1:36 PM
    #172
    Leggo
    Newton,Ma.
    The sliding rear window is by far my most used, favorite option.
  13. Oct 17, 2012 at 1:38 PM
    #173
    Leggo
    Newton,Ma.
    I did the same thing.
  14. Oct 17, 2012 at 1:43 PM
    #174
    Gotcha88
    CA
    That would be sick.. doesn't seem like it'd take much either.
    I prefer the clean look of a solid rear window.. and I know it's easier for the tint guys to work with :cool:
  15. Oct 17, 2012 at 3:09 PM
    #175
    Larry
    Larry CARL
    CARL
    I like the sliding rear window...I've used it several times for long pieces of moulding.
    and I don't recall seeing a Tacoma that the rear glass wasn't tinted. :notsure:
  16. Oct 17, 2012 at 3:17 PM
    #176
    Shauncho
    Shaun
    Parts Unknown...
    none
    ^^^ yeah, even my stepdads '96 taco AC has the rear "privacy glass"...
  17. Oct 17, 2012 at 6:43 PM
    #177
    Hiker
    Hiker Well-Known Member
    HotZona
    Mine's always within 1 or 2 of the current.
  18. Oct 17, 2012 at 10:10 PM
    #178
    Gotcha88
    CA
    Oh yeah, I didn't mean they don't come tinted. But for aftermarket tinting it makes it a bear vs just a flat window.
  19. Oct 18, 2012 at 3:42 PM
    #179
    Leggo
    Newton,Ma.
  20. Oct 18, 2012 at 3:49 PM
    #180
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Privacy Glass on the rear and side rear window has no heat reflection.. if you live in a hot area tint over those windows and you will notice a nice reduction in heat. I hate how manufactures put Privacy glass stock...
