Worst oil filter design
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newfiebruh, May 3, 2018.
  1. May 3, 2018 at 10:37 AM
    #61
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    How are you going back and forth to the store? Your bike ?
  2. May 3, 2018 at 10:39 AM
    #62
    Newfiebruh
    Newfiebruh [OP] Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    If I were to guess, the guy who put it on used one of the metal attachments that go on wrenches and he went to town with it
  3. May 3, 2018 at 10:39 AM
    #63
    Newfiebruh
    Tom
    yep I've been taking the R3
    spitdog[QUOTED] likes this.
  4. May 3, 2018 at 10:40 AM
    #64
    TallTallPines
    TallTallPines '10 Barcelona RC
    Opelika, Alabama
    What I found best for me on the 2.7 doesn't require lifting the truck. Crawl underneath from the passenger door and you'll be able to reach up to the filter with your left hand and also undo the drain plug without much fuss.
    DGXR and BillsSR5 like this.
  5. May 3, 2018 at 11:04 AM
    #65
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    OP, if you're truly unsatisfied with where the oil filter is located- you can get this relocation kit on RockAuto, and just buy the lines (best option is using trans cooler lines) at a store (or online). They're extremely popular in the diesel world, as well as boosted applications.
    This also, in theory will allow you to mount it at any angle you wish.
    This is one location another member used for his relocation. You can trim the skidplate to avoid having to take it off every oil change, as well.
    Slashaar and nocturne like this.
  6. May 3, 2018 at 11:29 AM
    #66
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Nifty kit. Doesn't look like that hard of a job.
  7. May 3, 2018 at 12:44 PM
    #67
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And there you go... Insulting poor innocent monkeys.
  8. May 3, 2018 at 12:50 PM
    #68
    Jimmyh
    SC
    2012 Prerunner SR5
    Sorry OP, but I have to ask.
    Are you sure you are turning the filter in the correct direction to unscrew it?
    Righty Tighty, Lefty Loosey
    It is easy to get confused when you are upside down.
  9. May 3, 2018 at 12:58 PM
    #69
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    No it's not, it's still Lefty Loosey.
    Newfiebruh[OP] likes this.
  10. May 3, 2018 at 1:05 PM
    #70
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if you just unscrew enough to let the oil drizzle down the side of the filter into the pan, and let it run out. another great option i haven't used is to poke a hole in the bottom of the filter to let the oil drain out of the filter then remove, some dude does this he uses a nail/knife to poke a hole with
  11. May 3, 2018 at 1:09 PM
    #71
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    That would be amazing if he was turning it the wrong way the entire time, ha!
  12. May 3, 2018 at 1:31 PM
    #72
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    It’s lefty lockie, righty relaxie
    ecoterragaia, henryp and Slashaar like this.
  13. May 3, 2018 at 1:39 PM
    #73
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
  14. May 3, 2018 at 2:07 PM
    #74
    Newfiebruh
    Tom
    Haha that would be better if I was but sadly it’s the right way
  15. May 3, 2018 at 2:19 PM
    #75
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    The right way is the wrong way. Left is right. o_O
  16. May 3, 2018 at 2:56 PM
    #76
    Jimmyh
    SC
    2012 Prerunner SR5
    I have seen people do this... sad as that is. Sort of like draining the transmission fluid while changing the oil.
  17. May 3, 2018 at 2:57 PM
    #77
    Jimmyh
    SC
    2012 Prerunner SR5
    On what planet is that? o_O
    Bebop[QUOTED] likes this.
  18. May 3, 2018 at 3:21 PM
    #78
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
  19. May 3, 2018 at 3:51 PM
    #79
    Newfiebruh
    Tom
    Update : it was a success, I went back and bought a more heavy duty version of the filter wrench and it came off with great force. Never letting an quick lube place even glance at my truck again lol
  20. May 3, 2018 at 5:28 PM
    #80
    Bebop
    Nick
    Keeps me alert
    Jimmyh likes this.
