Worth fixing up a Tacoma SR 2WD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdGenEd, Feb 22, 2021.
  1. Feb 22, 2021 at 7:31 PM
    3rdGenEd
    3rdGenEd [OP] Active Member
    2021 Tacoma Trail Edition 4x4
    What’s up Tacoma world I’m new here! Had a quick question want to know what you guys have to say. Do you guys think it’s worth fixing up a Tacoma SR 2WD?
    NightHawkTaco420 likes this.
  2. Feb 22, 2021 at 7:33 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Sure. What do you plan on doing with it?
    CONVERT IT INTO A TRD PRO PLS
  3. Feb 22, 2021 at 7:36 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I assume you are getting an awesome deal of some kind? I would fix one up. But not sure what your plans are for it.
    3rdGenEd[OP] likes this.
  4. Feb 22, 2021 at 7:45 PM
    3rdGenEd
    I did get a pretty good deal on it I’m in California so prices are crazy on Tacoma’s over here. And so far I have little things on it I’m going more towards like off road look just don’t know if it’s worth it cause it’s 2WD
  5. Feb 22, 2021 at 7:46 PM
    brandon78lusch
    Brandon
    Lockers with good tires will do the trick. Is it a V6?
    3rdGenEd[QUOTED][OP] likes this.
  6. Feb 22, 2021 at 7:51 PM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Few SR RWD's have that. It wasn't until the SX package was introduced that you could get a V6 and RWD (and only in an Access Cab like all other SX's). Otherwise, SR's only had V6's if you got the DCSB and 4x4. There's also the super, super rare 2016 fleet trucks, but I believe those were only 4x4 as well.
  7. Feb 22, 2021 at 7:53 PM
    3rdGenEd
    Yea I’ve been seeing that a lot that lockers is the way to go and no that’s the other thing it’s a 4cyl but comes with the gear selection which I know would somewhat help out on trails.
  8. Feb 22, 2021 at 7:54 PM
    brandon78lusch
    Brandon
    Yea I think I remember that. I have a huge list of just about every configuration possible for the 3rd gen. It should show up under this post if you’re reading it on a computer
    RustyGreen likes this.
  9. Feb 22, 2021 at 7:57 PM
    Snaeper
    Martin
    Phoenix, AZ
    I'm not seeing it, unless I got the years wrong, but I'm pretty sure it was 2016.
  10. Feb 22, 2021 at 7:58 PM
    RatDaddy
    Roy
    None
    There are lots of off roaders in SoCal, who are using 2wd trucks off road. With a good rear locker you can go many places, just not the most technical climbs.
  11. Feb 22, 2021 at 7:58 PM
    brandon78lusch
    Brandon
    Okay. Was it the 4WD access cab with the 4cylinder?
  12. Feb 22, 2021 at 7:59 PM
    Snaeper
    Martin
    Phoenix, AZ
    IIRC the rare fleet-code trucks were available as either an ACLB or DCSB, with 4x4, V6 and the 6MT
    shakerhood likes this.
  13. Feb 22, 2021 at 8:04 PM
    NightHawkTaco420
    NightHawkTaco420 Well-Known Member
    DFW, TX
    2017 SR5 Access Cab
    - Ceramic tinted windows all around - Morimoto XB headlights - Spyder tail lights - TRD grill - TRD OR charcoal/machined wheels - interior chrome delete - interior LED bulb switch - weathertech mats (F/R) - MESO Customs Ultimate 3rd Brake Light (BD3 Model) - Tuff Skinz Door Sill Protectors Planning a 3/1 lift/level project and a few other future mods
    Hell yes it is! I'm in the process of doing the same exact thing right now! Following this thread
  14. Feb 22, 2021 at 8:05 PM
    3rdGenEd
    Know of any good lockers?
    RatDaddy[QUOTED] likes this.
  15. Feb 22, 2021 at 8:05 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What's wrong with it? Photos too, please!
  16. Feb 22, 2021 at 8:08 PM
    3rdGenEd
    Awesome! Just wanted to see what people had to say or what ideas they have, cause I know there’s people out there that would not agree on doing so cause it’s not a TRD but dope to see people out here are for it!
  17. Feb 22, 2021 at 8:09 PM
    RatDaddy
    Roy
    None
    Eaton and ARB. ARB uses a compressor which would be even better for you because you can air down in tougher areas when off roading.
  18. Feb 22, 2021 at 8:10 PM
    3rdGenEd
    Nothing wrong with it it’s a 2019 Tacoma SR access cab and wanted to see what the Tacoma world would suggest if it’s worth fixing up/modding it.
  19. Feb 22, 2021 at 8:13 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    Do whatever you want with it its your truck. Here's my 4 cylinder 2wd
    TacoMike89, Malvolio, laftaco and 5 others like this.
  20. Feb 22, 2021 at 8:15 PM
    3rdGenEd
    Super clean! The light set up you have is what I want to do to mine look really good.
    LilTexan22[QUOTED] likes this.
