Would 1" spacer lift affect off road performance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SLOH, Oct 6, 2009.
  1. Oct 6, 2009 at 8:58 AM
    SLOH
    SLOH [OP] Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    i'm wondering if a 1" spacer lift would produce a noticeable difference in off road performance/some other side affects of running one. i'm currently running and ome set up. I'm looking to get a new leaf pack in back and get rid of my 2 inch block but most leaf kits are 2.5" to 3" and i can't run a 1.5 cause i'm running 33" tires. So i think i'm going to have to put a 1" spacer up front to keep my truck level...i already have 3" in front, is an extra inch going to affect more things in front that i'm not thinking of?
  2. Oct 6, 2009 at 10:13 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd wait and see if the leafs settle before adding a space in the front.
  3. Oct 6, 2009 at 12:24 PM
    SLOH
    Scott
    Los Angeles
    you think a 2.5" leaf kit would settle almost .5"
  4. Oct 6, 2009 at 12:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It could.
  5. Oct 6, 2009 at 12:33 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    dont we say no no to stacking lifts??
  6. Oct 6, 2009 at 12:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Generally, Yes. BUT, if he is talking about a 1" lift, then that would be a .5" spacer, and if he has aftermarket UCA's, he should be fine. Anything larger than a .5" spacer, is going to jepardise the Ball joints (If running OEM UCA's), and could possibly lead to shock damage.
  7. Oct 6, 2009 at 12:41 PM
    SLOH
    Scott
    Los Angeles
    ok yeah thats what i was thinking, the increased lift in front would wear out my joints faster and i have stock UCA but theyre on the top 3 list along with this leaf kit and single res. rear fox shocks...i'm sick of blocks, so for a .5" spacer w/o UCA would jeopardize but with UCA not so much...so a 1" spacer is going to jeopardize ball joints regardless correct?
  8. Oct 6, 2009 at 1:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  9. Oct 6, 2009 at 1:30 PM
    SLOH
    Scott
    Los Angeles
    okay thanks, and can you explain how a 1" spacer lift is a .5" spacer? and i was planning on putting the UCA, leafs and rear shocks on all at once, so i think adding the .5" spacer will be fine then.
    people on ttora are also saying that this leaf kit moves the axle forward so to avoid rubbing with my 33"s i'm going to need an axle relocation plate...? why are there so many hidden aspects to suspension??:mad:
  10. Oct 6, 2009 at 2:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shock location on the fron tsuspension is at the halfway point in the suspension travel. Thus a .5" spacer will yeild 1" lift. No idea on if you need a relocation plate or not. I havent heard of one being needed on the second gens.
  11. Oct 6, 2009 at 3:55 PM
    SLOH
    Scott
    Los Angeles
    okay, how do spacers affect spring compression, wont the coils have less room to compress and make the front suspension a little bit stiffer so a little bit less articulation
  12. Oct 6, 2009 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A top plate spacer lengthens the shock/spring assembly, and a Pre load spacer Pre loads the spring to a higher spring rate.
