Would 884's and stock rear be level or nose high?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DestinTaco, Jul 29, 2011.
  1. Jul 29, 2011 at 3:08 PM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    Also, how many inches difference is there between front and back on a stock Taco? TIA
  2. Jul 29, 2011 at 3:11 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do you have the tsb done?
  3. Jul 29, 2011 at 3:18 PM
    DestinTaco
    Destin, Fl
    I don't think so. Sorry, not sure what that means. How would I know?
  4. Jul 29, 2011 at 3:20 PM
    97yota4wd
    Eric
    Mesa, AZ
    how many leaf springs do you have in your rear leafs?
  5. Jul 29, 2011 at 3:26 PM
    DestinTaco
    Destin, Fl
    I currently have a 2" AAL
  6. Jul 29, 2011 at 4:12 PM
    DestinTaco
    Destin, Fl
    I have 4 counting the 2" AAL
  7. Jul 29, 2011 at 4:25 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I'm confused after reading all the above comments.
    But I installed 884's on the front of mine and it was nose high until I did the rear. That was without the 1/2 spacers. I'm going back in and having the spacers put on though, I want it to be more level.
  8. Jul 29, 2011 at 4:43 PM
    DestinTaco
    Destin, Fl
    How would I know if I had the tsb done?
  9. Jul 29, 2011 at 4:45 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    did you take it in to have it done.....?
  10. Jul 29, 2011 at 4:45 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    It would be pretty darn close to level with the stock 3 leaf pack. With a 2" aal your gonna have a slight rake.
  11. Jul 29, 2011 at 4:46 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Why do you say stock rear if it has a 2" aal? That's not stock...
  12. Jul 29, 2011 at 4:50 PM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    Toyota Service Bulletin
    0305-08 SEP 08 Suspension - Rear Spring Harsh Ride
    Has to do with a service on stock springs bottoming out, etc. Changes your leafs from a 3 pack to a 4 pack. Not sure if there is a TSB for 2011 models
  13. Jul 29, 2011 at 5:00 PM
    DestinTaco
    Destin, Fl
    I know that. Just wondering in case I took out the AAL.
  14. Jul 29, 2011 at 5:11 PM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    if you use the spacer it will be pretty much level, no spacer you'll have a some rake
