Would a 22re bolt onto a 6 cylinder truck ?
Discussion in 'Technical Chat' started by Crow84, Nov 8, 2018.
  1. Nov 8, 2018 at 7:43 PM
    Crow84
    Crow84 [OP] Active Member
    2003 toyota tacoma pre runner
    Me
    1995 toyota tacoma had a 6 cylinder but messed up on it would a 22re bolt onto it instead ? Would i need a computer too? Any info greatly appreciated. :fingerscrossed::curls:
  2. Nov 8, 2018 at 7:56 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Are you sure that’s a Tacoma you’ve got there? Is it a 3.0 or 3.4?
    Either way you’ll need an ECU, yes.
    Bell housings will be different.
    Auto? Stick? Tell us more.
  3. Nov 8, 2018 at 8:01 PM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    If you're in Texas I'd know plenty of people willing to trade their 22re for a 3.4
    Crow84[OP] likes this.
  4. Nov 8, 2018 at 8:04 PM
    Crow84
    Me
    Its a craigslist truck i was interested in the motor had went out . I believe it was a 3.0 stick . Ive been looking for a 91-95 22re efi tacoma but only seeing v6 ones for sale so i wanted to find out just in case. Thanks for your info .
  5. Nov 8, 2018 at 8:04 PM
    Rujack
    Did it blow the head gasket(s)?
  6. Nov 8, 2018 at 8:05 PM
    medic2230
    Murph
    Bama! Roll Tide
    I guess the real question is would the 22re be enough power for the bigger truck.
  7. Nov 8, 2018 at 8:05 PM
    Rujack
    Anyway it’s not a direct bolt up. Different trans, transfer case, motor mounts etc.,
  8. Nov 8, 2018 at 8:06 PM
    Rujack
    22re is way better imo
  9. Nov 8, 2018 at 8:08 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    I know Summit Racing make adapter plate for many mods of the like as for ECU that would entirely depend on what 22R you went for like a carburetor unit with good ole points type ignition it can be a very basic set up however better check with regulations about going with older engine since that truck is only 23 years old I think you can do what you want if it is 25 years or older but I am not the expert on that...
  10. Nov 8, 2018 at 8:37 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    If it’s a 3.0 then you’re looking at a pickup, not a Tacoma. And no the 22re does not even come close to bolting in. Find a 3.4 to swap or put another 3.0 in.
    Than what?
  11. Nov 8, 2018 at 10:00 PM
    Rujack
    3.0
  12. Nov 9, 2018 at 8:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All depends just how much of a budget you have .
    Depending on your skills the relocation of the frame mounts that the motor mounts attach to.
    for all the work this takes you may as well do a 3.4 swap almost as much work
