Would a 4cyl be wise?
Discussion in '4 Cylinder' started by Fenrisulfr, Jan 17, 2011.
  1. Jan 24, 2011 at 7:13 AM
    deo1929
    deo1929 Well-Known Member
    Dennis
    Central Indiana
    4 cyl. 4X2 access cab
    Convenience package, Toyota VIP alarm, Variable speed wipers, tonneau cover, 2011 factory radio with MP3 CDm Scangauge II
    Another consideration is that the higher the lift, the more angle you will have in your drive shafts between the differential and transfer case. Increased angle means increased wear unless you upgrade the U-joints. Everyone here is correct. Bigger tires will kill your gas mileage for 2 reasons-1. effectively lower (numerically) your gear ratio making it harder to get the truck moving. 2. increase the rotational mass due to increase tire weight. It will also throw off the accuracy of your speedometer (will read "slower" than actual speed). Lastly, a "mud" tire doesn't necessarily perform as well as a "snow" tire. They are designed with different rubber compounds and tread design as mud and snow have different traction characteristics. Whatever you choose to do, be sure to check with the experts...and there seem to be plenty of knowledgeable people on his forum with "real-word" experience. Good luck.
  2. Jan 24, 2011 at 7:21 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    you don't need 38" tires and lift. Just get some dedicated soft compound snows in OEM size or if you are in a state the allows, pick up a set of studded snows. problem solved.
