Would a maf sensor cause?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lake98taco, Oct 21, 2016.
  1. Oct 21, 2016 at 8:15 PM
    Lake98taco
    Lake98taco [OP] Member
    98 black Tacoma
    Headers muffler lifted three levels noes
    would a maf sensor cause your exhaust to glow red hot or maybe an o2 sensor
  2. Oct 22, 2016 at 1:14 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    My first guess would be a clogged cat. But not sure about the others. Doubt it tho. I would start with a back pressure test.. Have you been experiencing sluggishness?
  3. Oct 22, 2016 at 9:59 AM
    Lake98taco
    98 black Tacoma
    It does not have any cats there deleted with after market exhaust system
  4. Oct 22, 2016 at 10:18 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    What kind of header? Maybe it's cheap with thin walls. :notsure:
  5. Oct 22, 2016 at 10:49 AM
    Lake98taco
    98 black Tacoma
  6. Oct 22, 2016 at 11:31 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    A MAF could potentially cause this. If it were to tell the ecu theres alot less air than there actually is entering the engine causing a lean condition. the o2 should pick this up however and throw a code. noticed in your other thread you replaced fuel pump but did you change the filter?
  7. Oct 22, 2016 at 11:55 AM
    Lake98taco
    98 black Tacoma
    Yeah I did its throwing a code now for the o2 sensor on bank one
  8. Oct 22, 2016 at 1:23 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Interesting the MIL must be on all the time .
    i am guessing your only running the up stream O2 sensor
    If for some strange reason the Mass Air Flow Sensor is sending a false signal or the ECM is seeing one that tells it the Air Flow volume is the same it sees at 6000 rpm at idle your sill physically limited by the size of the injectors
    The engine would be running rather poor no doubt lots of black smoke
  9. Oct 22, 2016 at 2:37 PM
    Lake98taco
    98 black Tacoma
    There both on and plugged in I'm completely stumped going to pull the cover off and check the timing also but no smoke just runs shity when you can get it to fire up and when you put it to the floor it Boggs out and won't do anything and if you very slowly give it has it will rev to about 3.5k Rpms and cuts out and the exhaust pipe got red hot
  10. Oct 22, 2016 at 2:54 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I've seen my header glow dull red after a highway drive at night, not on a tacoma it was a 20R, no cats.
  11. Oct 23, 2016 at 12:43 PM
    Lake98taco
    98 black Tacoma
    Figured out what my problem is the crankshaft timing gear is messed up where the key way goes in to hold it in place is wallered out so it letting the timing get off by quit a bit
    devinzz1 likes this.
  12. Oct 23, 2016 at 3:14 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    At least you got it figured out
    DustStorm4x4 and devinzz1 like this.
  13. Oct 24, 2016 at 11:53 AM
    Lake98taco
    98 black Tacoma
    I did I also got a complete running 3.4 with 198k for parts motor for 200$
    DustStorm4x4 likes this.
  14. Oct 24, 2016 at 2:12 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Did you just get this truck??
    Did the timing belt and reused the old Crank Bolt??
    Torqued it to Feels tight enough
    I have been Guilty of doing the above over the years
  15. Oct 24, 2016 at 2:18 PM
    Lake98taco
    98 black Tacoma
    I got it awhile ago it's only got 96k original miles the guy befor me did timing belt about 15k ago and must not have got everything tight enough but I got a spare motor now so if anything else happens to g wrong to have everything I could need spare
