Would I even need a rear lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Sep 17, 2010.
  1. Sep 17, 2010 at 11:54 AM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I just received my 5100's for the front today. I already have the 4 leaf pack in the rear. The difference in fender height between front and back is 2.5". I was going to set the shocks to 2.5". Do I even need to do anything with the rear? I was going to add Ride Rite airbags too, if just to keep the rear level. Thoughts?
  2. Sep 17, 2010 at 1:00 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    Are you towing or carrying heavy loads (that's what she said) and need airbags? I think it'll look good with just the 5100s in the front and stock rear. Here's my truck with coilovers set 1.75 and stock (no lift) rear w/ 3 leaf pack. Second pic is coilovers at same height plus 1.5 AAL in the back.
  3. Sep 17, 2010 at 1:03 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    you shouldn't but i like my rear a little higher than the front. You should be pretty level with 2.5" of lift up front and the rear tsb springs.
  4. Sep 17, 2010 at 1:12 PM
    Priddle
    I have a snowmobile I put in the back plus a ramp system...about 700lbs...during the winter months. That's when I figure airbags would come in handy. My plan was to gain lift in the rear using airbags but at most I think the airbags will be good to keep it level
    thanks for the replies
  5. Sep 17, 2010 at 1:17 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yea you should be good with that setup. :thumbsup:
  6. Sep 17, 2010 at 1:19 PM
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    Has your rear had time to settle? It will generally settle about half an inch. My measurements are less than .25 inch difference front to back, set on 1.75 with 4 leaf pack. After settling of course.
  7. Sep 17, 2010 at 1:40 PM
    Priddle
    I don't know if it has settled. I took possession of it 2 weeks ago with 45000kms on it. I think it came with the 4-leaf pack when it was new as it's a Canadian truck. I'll see what happens I guess!
  8. Sep 17, 2010 at 4:29 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    i think measuring the fender height is the wrong way of doing it.
    the fenders are not cut the same, more opening in the rear.
    setting the billys at 2.5 will probably make you nose high
  9. Sep 17, 2010 at 4:58 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    Set the 5100's at 1.75" with the 4 leaf rear (factory or with TSB) and you'll be level.
  10. Sep 17, 2010 at 5:00 PM
    jandrews
    '09 FourDubDee TRD OR
    Level trucks sag when hauling or towing.
    Trucks should have a rake. Lift the rear a bit.
  11. Sep 17, 2010 at 6:08 PM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    You don't NEED to lift it at all.
    What are you trying to achieve by doing so?
    Is it just the cheapest path to a certain look?
    Do you want more clearance?
    Are you planning bigger tires?
    The reason for your lift should point to the correct answers.
  12. Sep 18, 2010 at 3:36 AM
    Priddle
    I am getting 18" rims and 265/70r18's. Those tires are just over 32" in height.
  13. Sep 18, 2010 at 4:22 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    Use your jack under the front and jack it up 2.5". I did that and am glad I did. I had the tsb last year and it has settled a lot. Even 1.75 was nose high. I installed them at .85 yesterday and it raised me exactly one inch. The rear fender is exactly 1 inch higher than the front which looks pretty level to me with a very slight rake. The rear fender is cut higher too so getting them equal would leave your nose high. I'm sure all trucks are different but in my case the jack was a great way to see where I wanted to be.
  14. Sep 18, 2010 at 5:46 AM
    zebra1550
    zebra1550 Well-Known Member
    Midwest
    4X4 SR5 DC OR Package
    16X8 Raceline Renegade 6's, 265/75R16 Revo 2's, Jason Tonneau, De-Badged, De-Chromed, Wet Okole's, 5100's & Rear TSB, Window's Tinted
    It looks way better with the AAL. My 2005 tacoma had 5100's set @ 1.75 and TSB springs. Even though it was technically level, it looked nose high to me. My 2010 is sitting on 5100's set @ 0.85 w/TSB springs, and looks better with a slight rake. Right now I'm sitting at 36" front, 37" rear, but would like to get the Toytec coils to accomodate a heavier bumper. You just convinced me to get an AAL when I get my coils.
  15. Sep 18, 2010 at 5:53 AM
    Priddle
    I see what you're saying now about the fender cut.
    Tim...nice truck BTW :thumbsup:
  16. Sep 18, 2010 at 6:16 AM
    Priddle
  17. Sep 18, 2010 at 8:40 AM
    Tim A
    Montana
    I agree with you. I liked the look OK with just the front lift but anytime there's a load/heavy bumper etc it would be nose high. Truck needs a rake when unloaded if you don't air bags, like me.
    Thanks
