Would I need a cab mount chop if..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charliecaricofe, Mar 13, 2019.
  1. Mar 13, 2019 at 5:53 AM
    Charliecaricofe
    Charliecaricofe [OP] Well-Known Member
    Charlie
    2009 Silver Prerunner tacoma
    I plan on getting a 3 inch lift, that’s a definite. But I have the possibility of putting either 18s on, and 275/70r18 on. Or a 16 inch rim and 33s. Would either or need or not require a cab mount chop to not rub? I’m fine with taking the mud flaps off to prevent that rub. Thanks everyone for reading
  2. Mar 13, 2019 at 5:54 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Running a 3" lift on 285/75/16's and I did a CMC. If you don't plan on going off pavement or cycling the suspension at all, you MIGHT be okay. Every truck is different however. It's not an exact science.
    Beretta4x4 likes this.
  3. Mar 13, 2019 at 5:56 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Any offroad? Then yes. Mallcrawling? Then no.
    Charliecaricofe[OP] likes this.
  4. Mar 13, 2019 at 6:08 AM
    Charliecaricofe
    Charlie
    I may do the occasional dirt road, hitting the occasional ankle deep mud hole, but Other than that I won’t do much off-roading. What do you think
  5. Mar 13, 2019 at 6:11 AM
    geekhouse23
    Install them and chop if you need to. Again, it's not an exact science
  6. Mar 13, 2019 at 6:20 AM
    Charliecaricofe
    Charlie
    Thanks for your help. Have a great day
  7. Mar 20, 2019 at 8:20 PM
    Bridger
    Bridger Well-Known Member
    South Jordan, UT
    2016 Tacoma TRD Off Road
    3" Lift 33" Tires on stock 16" rims Body Armor Rock Steps Decked Drawer System
    I have 285/75/16s on stock rims under a 3” lift and front end leveler.
    The issue isn’t the tallness of the tire, but the width of it. The truck is my DD, and I do some off-road driving.
    I’m getting some gnarly rubbing noise when turning and stuffing even a little bit (like turning int a driveway). When I look at the wear spots, I will need to trim some of the wheel well liner and do a cab mount chop.
    Others have said it: each truck is slightly different. Each tire brand is slightly different. I’d put them on and see what happens.
    Pugzly29 likes this.
  8. Mar 20, 2019 at 9:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    FWIW i have 275/65/18 under a 2-2.5 inch lift, still have mudflaps and no rubbing at all
  9. Mar 20, 2019 at 9:13 PM
    Bridger
    South Jordan, UT
    Yep. It’s the width...
    Thunder Fist likes this.
  10. Mar 20, 2019 at 10:27 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    This.
    I run 285s and do not have a cab mount chop, but my alignment pushes the wheels as far forward as possible and I had to trim the flares and fender liners.
    I don’t wheel hard, mostly forest service roads and shit like that.
  11. Mar 21, 2019 at 9:05 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    If you go with the SPC UCA's that are adjustable, you might not need the cmc. I'm running 305/65/17 on 17x8.5 with -10 offset and had a little bit of rubbing at full lock on position D (my lca's are not maxed out). I just changed them to position E which pushes the tire further forward and the rubbing seems to be gone and I have not done the cmc. My mud flaps are gone and the flares are trimmed along with the pinch weld bent back. It will still depend on the brand tire, size and wheel (width and offset) as to whether the tire might contact the mount.
    steveo27 likes this.
  12. Mar 21, 2019 at 11:23 AM
    Tantrd08
    Tantrd08 Active Member
    Nick
    08 trd off-road
    Rough country 3in lift/level Magnalfow off-road exhaust 265/75r16 Duratrac tires
    I have 3in lift and level with 285/75 on aftermarket 16s, I did the chop and cut out a lot of plastic in the front too
  13. Mar 22, 2019 at 10:51 AM
    Pugzly29
    Pugzly29 Member
    I run a 285/75 16 (ruffly 33.1 x 11.3) with mud claw XT (aggressive) on stock rims. i had to cut the cab mounts. The lugs on tire would still rub on the UCA when i turned. Add 2 in spacers and then had to cut some plastic:sawzall:
