would i need a lift
Discussion in 'Suspension' started by broken taco, Nov 9, 2011.
  1. Nov 9, 2011 at 9:31 PM
    broken taco
    broken taco [OP] Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    would i need to put MT or LT on to get the fender flares to look good or do you think it look fine with the 2 1/2 in spacer i have in the front. and BFG mud terrains. http://www.glassworksunlimited.com/19to20topa.html
    and i want the 4.5in in front and back
  2. Nov 9, 2011 at 9:33 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    That hurt my brain trying to read....
    but how "good" something looks is completely subjective, it's up to you to decide what you want
    LT isn't a lift
    and
    if you spend $1000's of dollars to make fender flares look good, the more power to you,
    but do you need them? Do you offroad?
    other members have run fender flares with normal lifts and liked them. in the end it's alllllll up to you
  3. Nov 9, 2011 at 9:36 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    haha sorry. didn't mean to hurt your brain. but do you think it would look fine with just a 2 1/2in spacer or do you think i should get long travel or mid travel suspension to make it look good.
  4. Nov 9, 2011 at 9:37 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    I added to my post.
    Its up to you.
    but you realize "should I just go LT to make them look good" = "Should I spend $12,000+ to make them look good" right?
  5. Nov 9, 2011 at 9:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    basically OP, people get the fenders after they get the suspension because they need them.
    they don't usually get the flares then the suspension to make the flares "look good"
    IMO, save your money for a better lift, then think about flares.
  6. Nov 9, 2011 at 9:53 PM
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
  7. Nov 9, 2011 at 9:55 PM
    pyroskier
    Jacob
    Laramie, WY
    x2
  8. Nov 9, 2011 at 11:40 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Only add them if you need them.......and it sounds like you prob won't!
  9. Nov 10, 2011 at 11:22 AM
    ColdSteelTiger
    ColdSteelTiger Well-Known Member
    Though LT was a lift. Speaking of LT what will having the front LTed do and not the rear
  10. Nov 10, 2011 at 11:27 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Calling LT a "lift" is like calling a
    a "truck"
  11. Nov 10, 2011 at 11:30 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Long Travel is a suspension system not a lift. That's like saying I'm installed a SAS lift :facepalm: a lot of guys do it one at a time you just don't have full LT until the front and rear are done.
  12. Nov 10, 2011 at 11:31 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    __________________________:D
  13. Nov 10, 2011 at 11:33 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    in all seriousness op 3 inch ome kit or billies get your fenders make it look cool then 285's or something your truck will then look like you want it to and you will save about 12,000 dollars :)
  14. Nov 10, 2011 at 11:36 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    im going to guess you tried to say this.
    Thought LT was a lift? Speaking of LT what will having the front lted do while the rear end is not long traveled.
    it does lift the truck, but people do not buy long travel for a lift. they buy it for the better suspension.
    the rear end will always limit you, so you will not be able to hit stuff as fast when doing prerunning. if you want a capable lt truck you must do the rear also.
  15. Nov 10, 2011 at 4:18 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    if i get LT i will put it in the front and rear. but do YOU THINK the fenders would look good without LT.
