Would like to know what this is
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kilinito1, Nov 23, 2024.
  1. Nov 24, 2024 at 6:12 AM
    Kilinito1
    Kilinito1 [OP] Member
    2017 trd sport
    Front grille, 2.5 lift
    Yessir that's how I've gotten most of my information by back tracking in this here forum searching and seen quite a few of threads and the comments of ppl that have made engine repairs because of this here weak point. I call this cause and effect. No where in them threads did I see anyone suggesting to report to the NHTSA. I am a noob and have little to non knowledge on how to share this thread to other one but depending on what I gather on Monday that I call and report this to the NHTSA I will be manually searching and entering other threads that pertain to flapper, acis, etc
  2. Nov 24, 2024 at 9:24 AM
    BillyE
    BillyE Well-Known Member
    There won’t be a recall. What IS possible is that the aftermarket will develop an alternative.
    RIX TUX likes this.
  3. Nov 24, 2024 at 10:15 AM
    MGMDesertTaco
    Kilinito1[OP] and soundman98 like this.
  4. Nov 24, 2024 at 2:59 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I tried to find a you tube video on replacing/fixing it, no luck, could not find anything out there
    maybe someone here can have better luck locating a video on it
  5. Nov 25, 2024 at 7:08 AM
    Kilinito1
    2017 trd sport
    Toyota is not allowing any aftermarket so this has to be taken up with toyota directly.
  6. Nov 25, 2024 at 7:19 AM
    BillyE
    What do you mean? Toyota can’t disallow what the aftermarket develops. If this is some warranty thing, then just let a dealer relative it with a new part.
  7. Nov 25, 2024 at 7:44 AM
    Kilinito1
    2017 trd sport
    What i mean is that toyota doesn't release parts to be aftermarketed. Example: you can't go to autozone and get a certain part because it's only available at the dealership only.
  8. Nov 25, 2024 at 9:27 AM
    BillyE
    This is nonsense.
    KSchoppers and RIX TUX like this.
  9. Nov 25, 2024 at 10:07 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Please post proof from Toyota stating this.
    RIX TUX likes this.
  10. Nov 25, 2024 at 10:37 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
  11. Nov 25, 2024 at 12:03 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That’s not how that works at all.
  12. Nov 25, 2024 at 2:08 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    KSchoppers likes this.
  13. Nov 25, 2024 at 2:30 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Toyota contracts out parts for factory built vehicles from aftermarket companies. Bearings, brakes components, electronic modules etc. Then these manufacturers make the same parts with a different stamping to supply the aftermarket. This is standard operation in automotive manufacturing.
  14. Nov 26, 2024 at 2:28 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Seems like you can spot where the prong on each end came out of.
    Next determine why. With a little detective work you shud be able to figure out why it fell out and replace whatever you fine that may have been the cause for it to fall out. You need to get a diagram of it that shows all the parts involved. Hopefully all the parts are there and none missing! Just throwing that out there.
  15. Nov 26, 2024 at 6:13 PM
    #35
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    and generally, it's like any other non-name-brand alternative. alternatives generally use slightly looser specifications. in many cases, the alternatives will even be made with official branded moulds that were purchased from the oem, but have fallen out of oem spec from use.
    but it all comes down to money. for the aftermarket to come up with a replacement part solution, there needs to be enough part usage to justify building up the product from a source outside of the oem.
    Speedfreak[QUOTED] likes this.
