Would someone please help interpret these vacuum test results?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Aug 7, 2022.
  1. Aug 7, 2022 at 11:57 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I have to go back into the engine & figured I would attempt to dot & cross prior to doing so. Part of the plan is to do valve clearance checks. I also appear to have yet another VCG leak, which of course tells me more is going on. & as many know, there has been a high idle issue for quite some time now. In fact it started right after I did a major engine cleaning last June, injectors, gaskets, etc.
    Anyway, I do understand these vacuum test results are difficult to interpret, so I'm looking for input from those in the knw. A bit confusing between whether it's a high fluctuation or in the normal range fluctuation. Weird thing, or maybe not so weird with my driving it when unbeknownst to me maybe I shouldn't have been, is about a month ago, the check was all fine.
    https://youtu.be/w0sDm58pjoc
    https://youtu.be/d6aPP6ux5BU
    https://youtu.be/Y44kv93IZ7I
  2. Aug 7, 2022 at 4:03 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Kristi with a K[OP] likes this.
