Would spacers be a bad idea?
Discussion in 'Wheels & Tires' started by I Liquid I, Mar 17, 2010.
  1. Mar 17, 2010 at 11:23 PM
    I Liquid I
    I Liquid I [OP] Well-Known Member
    Puerto Rico
    06 BSP DCLB, 17 Inferno TRD Offroad DCSB, 06 SW ACLB
    Too many mods to list
    My Taco aint lifted but I want a wider stance on it. Would it be safe for me to use spacers? Would I create rubbing of any kind if I did that? I am running stock wheels atm.
    I was thinking about 1/50 spacer. Is that way too much?
    Thanks for all input!
    I know so little about this... :anonymous:
  2. Mar 17, 2010 at 11:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    IIRC, u can run spidertrax 1.25" spacers w/ stock everything and have no rubbing
  3. Mar 18, 2010 at 12:24 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Only down sides to wheel spacers are the leverage they put on your wheel bearings and wheel studs, otherwise you're fine to run them. Every once in a while check the wheel bearings for play.
  4. Mar 18, 2010 at 9:13 PM
    I Liquid I
    Puerto Rico
    TYVM for both your replies.
    One question though, will the added pressure that the spacers inflict cause me a lot of problems and possibly cause something to break?
  5. Mar 19, 2010 at 8:27 AM
    zkdawg
    zkdawg Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
  6. Mar 19, 2010 at 9:26 AM
    I Liquid I
    Puerto Rico
    Those dont seem to be hub centric. Will probably give problems.
