Would the anticipated rubbing be the same?
Discussion in 'Wheels & Tires' started by 90YotaPU, Mar 3, 2012.
  1. Mar 3, 2012 at 3:46 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I currently have a set of wheels and am looking at buying a new set. Offset and backspacing are as follows:
    Wheel A (16x8):
    Offset: 0
    Backspacing:4 7/16"
    Wheel B (16x8):
    Offset: -11
    Backspacing: 4"
    When I sketch it out on paper, it seems that the rubbing would essentially be the same (minimal) between them.
    Can anyone confirm my theory?
  2. Mar 4, 2012 at 8:03 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The second one will rub more. Folks have a lot harder time fitting 4.0" bs wheels than 4.5", because pushing the wheel further out makes the turning arc larger.
  3. Mar 4, 2012 at 9:24 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    I would've said the opposite. Pushing the wheel out further gets the tire away from the suspension. Its the reason people use wheel spacers to fit bigger tires, right? I could be wrong though, its happened before :rolleyes:
  4. Mar 4, 2012 at 11:26 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    it all depends on what size tire you're going to use and if you're lifted or not. stock sized tires, you should clear with either one.
  5. Mar 4, 2012 at 11:30 AM
    TexasTacoma37
    People use wheel spacers to push the tire just barely far enough from the UCA. Once you have done that, the further you push it out, the more rubbing you'll have on the fender wells.
    This^, but if you were to have rubbing with any particular size, the second one would be worse.
  6. Mar 4, 2012 at 11:47 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Correct:D.
