Would the increase in weight require me to do any upgrades?
Discussion in 'Armor' started by Denon123, Jul 7, 2021.
  1. Jul 7, 2021 at 3:55 PM
    Denon123
    Denon123 [OP] Member
    2021 TRD OR 4X4
    My most recent trail put some dents in my stock skid plate, this made me realize I should probably skid the entire underside with quality plates as a precaution. I would go with a full skid package, so it would add a lot of weight to the truck.
    Haven't decided on steel or aluminum yet, but would the increase in weight from either require me to make any modifications to my truck? As of right now, I have 5100's with OEM UCA's
    Monster0Frankenstein likes this.
  2. Jul 8, 2021 at 6:29 AM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    Start with the IFS skid to replace the one you dented up.
    Steel is real. If you wheel this is the way to go.
    See what that does to you ride and go from there.
    If you skid the whole truck with steel you are definitely going to notice.
  3. Jul 21, 2021 at 10:43 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I don't have any exact measurements but I lost around an inch when I added front and mid steel skids + sliders. This was more than I expected. That was on 3rd gen OR suspension. I since installed 2nd gen Pro suspension and got my height back.
    If you're on stock spring rates you'll likely see a decent drop in ride height due to a full steel skid package.
  4. Jul 21, 2021 at 10:50 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I don't want to be a buzz kill but I feel like you need gears stock. Add weight and cry
  5. Feb 4, 2022 at 8:35 AM
    heard4it
    heard4it Well-Known Member
    2006 Toyota Tacoma TRD Sport access cab
    Subbed. About to add full BAMF skids to my Tacoma with OME suspension and camper shell/sliders/ARB bumper already installed.
  6. May 1, 2022 at 8:52 AM
    Otto-x
    Otto-x Well-Known Member
    Seattle, WA
    2021 Cement DCLB OR
    I have the steel BAMF trilogy, a fiberglass ARE canopy, and roof+top racks on stock suspension. I notice the weight but it doesn’t seem to be a problem on the suspension. I might consider switching to aluminum skids when I put on the rock sliders.
  7. May 1, 2022 at 12:32 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s very subjective especially if you don’t use any numbers in your question.
    ilyace and wi_taco like this.
  8. May 9, 2022 at 10:18 AM
    gudujarlson
    Minnesota
    I think you are worrying about nothing. That's well within the payload capacity of a Tacoma.
  9. May 9, 2022 at 10:26 AM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    With just skids you'll be fine, bring a friend that weighs 150 pounds for a ride and that's what the weight difference will feel like, except with skids that weight is evenly distributed in a very ideal spot(low down) so the passenger will feel worse.
    Skids and sliders are fine on stock suspension. If you add bumpers too you'll need suspension.
    Actually if you add only bumpers you're more likely to need suspension, even if they weigh the same as the skids a bumper is concentrated weight hanging off the very front of the truck as opposed to more spread out weight in the center. That lever arm gives the bumper mechanical advantage over the suspension.
  10. May 9, 2022 at 5:37 PM
    gudujarlson
    Minnesota
    Don’t fix what’s not broken.
  11. May 13, 2022 at 6:02 AM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    The answer to your question is, no but yes. You don’t really “need” to do any upgrades until you notice the performance of your suspension drop beyond your expectations.
    The first thing you will notice IS the sag. BAMF IFS skid and steel sliders had my front end sagging a 1/2” on the stock OR coils. The ride became harsher. My rear end was sagging about an inch with a fiberglass shell and tools in the bed. So then I decided to upgrade the suspension.
    That being said, measure your suspension height before/after, pay real close attention to how the truck handles around corners, high speeds, BRAKING FROM HIGH SPEEDS, fire roads etc etc before the armor. If the armor affects your suspension’s baseline that much then you’ll know it’s time to upgrade.
