Would these exhaust leaks cause my trucks RPMs to go from 550-650 after warm up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bloodyxsocks, Apr 18, 2025.
  1. Apr 18, 2025 at 8:45 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Speaking of stink: Decades ago I was changing some ancient diff oil (hypoid) and my wife decided to visit the garage. To this day she wants to barf just from me reminding her. That is some serious stank.
    ControlCar likes this.
  2. Apr 19, 2025 at 5:15 AM
    bloodyxsocks
    bloodyxsocks [OP] Well-Known Member
    1995.5 Toyota Tacoma 4wd
    I use a scan gauge for coolant temps and rpms due to my truck not have a tach. The truck starts awesome it’s after it’s fully warmed up (188-190) that it’s starts having a small jitter. At the light I see my rpms go down to 550 and fluctuate to 650 max. Park its 700ish. I turn on the ac and the it tends to balance out making the truck run smoother. I can hear the cat rattle a bit and a bit of air coming out from where the gaskets go and side of the cat. Not sure if that’s relevant.
  3. Apr 19, 2025 at 5:18 AM
    bloodyxsocks
    just changed my rear differential oil due to a flood and hoo wee. I’d rather smell pb all day. Lol
    ControlCar and MadNachos[QUOTED] like this.
  4. Apr 19, 2025 at 12:40 PM
    MadNachos
    Yep. I remember ages ago when a friend bought some old crapped out 50's era truck. The smell of its 50 year old gear oil hung around the garage for a month. Smelled like death. I feel like I can taste it while remembering.
  5. Apr 19, 2025 at 12:47 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Reminds me of old supercharger oil….ugh
  6. Apr 19, 2025 at 5:19 PM
    MadNachos
    Sounds like vacuum leaks. Smoke it. It only takes a few small vacuum leaks before these engines idle like crap. And you can get a really capable smoker from Amazon for under $100. It's a hell of a diagnostic tool.
  7. Apr 19, 2025 at 5:55 PM
    Glamisman
    Glamisman Well-Known Member
    You can either squeeze off the vacuum line from the brake booster to the intake manifold or disconnect and plug it to see if the idle improves.
    If you can slide the throttle shaft back and forth or up and down even a little bit the idle will fluctuate.
  8. Apr 19, 2025 at 8:42 PM
    Sparky 97Runner
    Sparky 97Runner Well-Known Member
    Fair Oaks,CA
    2023 Tacoma Off Road 1997 4Runner
    How do your long term fuel trims look? Your engine probably having a hell of a time burning all that extra fuel. The first thing I'd do is fix all those exhaust leaks 100% and get your long term fuel trims in spec. You may have more than one problem causing this but the leaks have to be fixed no matter what. You already smoked the intake so you can pretty much rule that out.
  9. Apr 20, 2025 at 7:11 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    gear oil IS THE WORST
    Auto diff or lower unit from boats
    IMO…..3 days minimum to get rid of the stank from your hands
    MadNachos[QUOTED] likes this.
