Would these fit my truck? (CL ad)
Discussion in 'Wheels & Tires' started by CaptMorgan, Sep 12, 2010.
  1. Sep 12, 2010 at 8:00 PM
    CaptMorgan
    CaptMorgan [OP] Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
  2. Sep 12, 2010 at 8:01 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    The rims will, the tires won't unless you've got a lift
  3. Sep 12, 2010 at 8:02 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Yeah, 6-5.5/139.7 is our 6 lug bolt pattern. You're good to go.
  4. Sep 12, 2010 at 8:06 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    This
    And this :)
  5. Sep 12, 2010 at 8:06 PM
    CaptMorgan
    Tempe
    Thanks guys. I do have the 3" lift, but didnt know how the 9 in wheel would fit. I have rubbing right now so thats nothing new.
    Might be picking these up very soon...
  6. Sep 12, 2010 at 8:07 PM
    ColtsTRD
    Scott
    AZ
    hell yea dude...good luck and post up some pics if you get em :)
  7. Sep 12, 2010 at 8:07 PM
    Incognito
    VA
    This :)
  8. Sep 12, 2010 at 8:09 PM
    CaptMorgan
    Tempe
    Would be nice to have them before the run on the 18th :)
    Just need uncle same to hurry up already
  9. Sep 12, 2010 at 9:48 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    same lug pattern, but ad indicates they are for a chevy... if they are hub centric to the chevy, the center bore will be too small for a tacoma...
    according to the wheel manufacturer, they are a 6" backspace which sticks in about .5" more than a tacoma, and the center bore is 106mm...
    isn't the tacoma, 108mm?
  10. Sep 13, 2010 at 6:18 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The offset is way too high. Those will rub without 1.5" wheel spacers. 4.5" backspacing is ideal.
