would these wheels: 20" w/ 5.00 backspacing, -6.00 mm offset
Discussion in 'Wheels & Tires' started by solus, Apr 7, 2010.
  1. Apr 7, 2010 at 4:04 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    fit? assuming I have atleast 4.5" of lift.
    I have LR UCAs
    Bolt Pattern: 6 on 5.5
    Diameter: 20.00 "
    Width: 9.50 "
    Style: 89 Series
    Finish: Cast Blast
    Construction: Aluminum
    Backspace: 5.00 "
    Max Load: 2200 lbs
    Hubcentric: No
    Offset: -6.00 mm
    Thinking of doing a drop bracket lift with 20" wheels and 33x12.5x20 tires
    also considering 18" wheels
  2. Apr 7, 2010 at 8:03 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    really? no one
  3. Apr 8, 2010 at 6:44 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Pretty sure you are going to want 4-4.5" backspacing to fit a tire that wide, but I'm not positive.
  4. Apr 8, 2010 at 6:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^^seconds Keith's motion.
  5. Apr 8, 2010 at 11:57 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    shit thats what I was thinking...
  6. Apr 8, 2010 at 12:50 PM
    KPT
    09 Prerunner
    You could go with the 1.25" Spidertrax maybe?
  7. Apr 8, 2010 at 1:19 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah thats a possibility
  8. Apr 8, 2010 at 4:30 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    if it helps you... my wheels are 20x9 with 5.71 bs and 11.5" wide tires and it clears the stock uca. and with aftrmarket uca's you should be fine? but i'm not 100%
