Would these wheels fit on my 09 4x4
Discussion in 'Wheels & Tires' started by comicnut25, Sep 28, 2009.
  1. Sep 28, 2009 at 7:39 AM
    comicnut25
    comicnut25 [OP] Well-Known Member
    Rob
    Stanwood Wa
    09 TRD 4X4
  2. Sep 28, 2009 at 7:54 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    chrome wheels won't fit on tacos
  3. Sep 28, 2009 at 7:58 AM
    09blacktaco
    09blacktaco Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    :rolleyes: hahaha
  4. Sep 28, 2009 at 10:32 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    very funny guys! Did you not see the really cheap price?
  5. Sep 28, 2009 at 11:24 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Need more info.
  6. Sep 28, 2009 at 11:34 AM
    azTRD
    azTRD Well-Known Member
    OK... that made me laugh.
    The add lists 16"x 6 lugs with 5.5" spacing. The only question I have would be what the 5.5" spacing is referring to. Is that the bolt center spacing or is that the back spacing on the wheel.
    Essentially you will need to know what the bolt center measurement is and the back spacing measurement to determine if they will work. Find out this information and post your findings... then we can help determine if they'll fit. Also, are you putting this on a stock setup (i.e. not suspension modifications)?
  7. Sep 28, 2009 at 11:54 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    x2
  8. Sep 28, 2009 at 1:03 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Ask him if they're lug or hub centric.
  9. Sep 28, 2009 at 1:30 PM
    azTRD
    I see a lot of people driving the point of getting "hub" centric with wheel spacers. But from a wheel standpoint I see most people running "lug" centric wheels.
    Most after market wheels are lug centric with an over sized hub bore to accommodate a larger number of vehicles. I know you can buy hub rings to covert your lug centric wheels to hub centric... I'm just not totally convinced that it's worth it. Lug centric wheels have been around for a long time and most of the people running them have no problems. If you use the right lug nuts and torque them... lug centric wheels work just fine.
  10. Sep 28, 2009 at 3:27 PM
    johnecon2001
    Phoenix, AZ
    True, unless the hub bore is smaller than our trucks. Someone tried to fit a set of chevy wheels on the other day from a colorado, but the hub bore was too small.
  11. Sep 28, 2009 at 4:36 PM
    dexterdog
    Oly WA
    2012 F150
    Believe me, it is worth it to have a hub centric wheel whether it is by the design of the wheel or the use of hub centric rings.
  12. Sep 28, 2009 at 10:55 PM
    azTRD
    Can you elaborate... I'm just curious why you think it's worth it. What problems have you had?
    Thanks.
  13. Sep 29, 2009 at 5:12 AM
    dexterdog
    Oly WA
    2012 F150
    I had aftermarket wheels on my last car and I fought vibrations for the longest time. The cure was hubcentric rings.
  14. Sep 30, 2009 at 7:49 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    this is what i got back from the guy!? What do you think?
    6x5.5 Bolt Pattern with a 0mm Offset
    Rob
  15. Sep 30, 2009 at 12:54 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
  16. Sep 30, 2009 at 4:50 PM
    dexterdog
    Oly WA
    2012 F150
    What's the backspacing?
    I am going to jump out on a limb and say they probably won't fit. If you feel they are too good to pass up then worse case they don't fit and you turn around and sell them and probably without any loss.
  17. Sep 30, 2009 at 4:57 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
