would this be smart
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thisERICtaco, Feb 2, 2010.
  1. Feb 2, 2010 at 12:46 AM
    thisERICtaco
    thisERICtaco [OP] Well-Known Member
    Eric
    CA, oc
    06 AccessCab SR5
    as you guys may know already
    all the 4 banger trucks have the rear leaf springs under the drive axle
    and all the v6 ones have the springs on top of the axle
    since toyota did this
    is it ok to move the springs to the top of the axles like the v6's?
  2. Feb 2, 2010 at 3:17 AM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    Thats called a spring over axle conversion. Its pretty popular on some wranglers and other vehicles.
    If you did that, you would lift the rear end (axle tube diameter + 2*spring perch + leaf pack thickness)...which I would guess is somewhere about 5 or 5.5"
    So Id say probably not unless thats what your trying to do.
  3. Feb 2, 2010 at 11:52 AM
    S-M-R-T
    S-M-R-T Well-Known Member
    Yup it is a common cheap lift for any vehicle that came sprung under. You would have to weld on new spring perchs on top of the axle though.
  4. Feb 2, 2010 at 11:57 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    If your truck is a 5lug it is spring under in the rear. 6lug is spring over. If you move your 5lug rear to spring over it may require custom fab to the front suspension to match the rear lift height. I'm not sure if the total chaos front kit may match lift height.....
  5. Feb 3, 2010 at 12:14 AM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    o ok
    thanks guys
    i guess it wont be smart to do that
    ill leave it as is then
