Would this be the neutral safety switch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Mar 27, 2024.
  1. Mar 27, 2024 at 4:48 PM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    So over the last couple of days sometimes when I put the truck in park and turn the key to remove it it stops right before the off position. I can crank the truck back up when it does this. Sometimes hitting the shifter can make it free up but sometimes not. But if I disconnect the battery it seems to release whatever is causing the key to not turn to the off position. So am I right in thinking it's the neutral safety switch or could it be my key cylinder or something else entirely. Trucks a 2003 Tacoma V6 prerunner with 380k miles
