Would this indicate i might need a new clutch?
Discussion in 'Technical Chat' started by blackoctober, Apr 14, 2018.
  1. Apr 14, 2018 at 6:13 AM
    blackoctober
    blackoctober [OP] Member
    Hello, although i am not all that good at diagnosing engine problems I am concerned that i might have a clutch problem. I have noticed that when traveling down the road, in most any gear except 1st and 2nd, that if i accelerate the rpms shoot way up as if i had pressed in the clutch slightly. Sometimes it happens and sometimes not. This is something new in the last couple of weeks. My truck is a 2002 with 180000 miles. Still on the first clutch. Any thoughts on this issue?
  2. Apr 14, 2018 at 6:30 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Yep. Sounds like you're due for a new clutch disc, pressure plate and TO bearing
    You'll probably want to resurface the flywheel as well....unless you can verify that it's healthy
    mynewtoy and scottalot like this.
  3. Apr 14, 2018 at 6:40 AM
    blackoctober
    Hey thanks for the info, any idea what that might cost at the average car garage? Sounds like something i should let someone with experience deal with.
  4. Apr 14, 2018 at 7:09 AM
    Plain Jane Taco
    USA
    If you've had no real experience with such things...I would let a shop do it.
    Just make sure they actually replace the 3 components I mentioned. Also, if they remove or replace the flywheel, it's usually a good idea to replace the FW bolts with new ones.
    I would guess $300-$500. But frankly, I haven't a clue what the going rate is on a clutch job these days
    If you got 180k out of a clutch...you did well. Keep doing what you've been doing once the new one is in
  5. Apr 14, 2018 at 8:40 AM
    blackoctober
    Thanks, I will keep the info you mentioned. Its been a great truck. What does FW stand for?
  6. Apr 14, 2018 at 8:45 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Flywheel
    Plain Jane Taco likes this.
  7. Apr 14, 2018 at 1:20 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your clutch is slipping you should be able to smell it when you get out of the truck.
    Are you having a hard time getting it in gear once it gets hot??
  8. Apr 20, 2018 at 3:53 AM
    blackoctober
    no, always easy to shift from gear to gear.
